Air suspension problem
Old May 31, 2010 | 10:58 AM
silos5's Avatar
silos5
Default Air suspension problem
Hello everyone.
I have 98 LS400. I replaced some parts in the suspension, and I had to take the stock air bags off, so I disconnected the airlines, and after puting everything back together, only one bag got filled with air, another side is slammed to the ground! I pushed HIGH-NORM button, but its still empty.
Anyone knows what to do??
BTW, can someone tell me where the air compressor fuse is??
PLESE, HELP!
Old Jun 1, 2010 | 09:14 PM
silos5's Avatar
silos5
ok guys, seems noone know what to do
anyway, I had a plan on putting UAS+coils on the car, but I had this in plan after paint and other services, but I'm doing it now because I dont have a choise
I looked in the engine bay for the fuses and I didnt find compressor fuse there. Another box is on the right side where the passenger legs are, right?? may be there??
thanks
Old Jun 1, 2010 | 09:51 PM
trukn1's Avatar
trukn1
NELOC Mod
This may help a little with your problem. Sounds like you may have a bad connector/actuator as described in this thread.
https://www.clublexus.com/forums/ls4...rmittanly.html
IIRC, there is a control area in the trunk where the tools are in a drop down compartment, which is where your fuse may lie. I do not have air in my LS, so am sure that someone who does will chime in if I am mistaken.
Old Jun 11, 2010 | 10:11 PM
jkweller's Avatar
jkweller
did you check under the hood next to the battery should have a compartment in there with the fuse in it but i really wouldn't now on you newer model i got a 93 ls400 with stock air in process of swapping to coil conversion bags cost to much for me
Old Jun 12, 2010 | 04:05 AM
silos5's Avatar
silos5
hi,
thanks for replies!
I already on UniversalAir+BCR coils. I still hear my stock compressor making noise. I looked in the engine bay and I didnt find compessor fuse there. I also looked in the passenger´s side kick panel and there is nothing. I wiil look in the driver´s side kick panel, there must be some fuses.
watch out for some fresh pics soon
BNR34
Nov 21, 2023 07:35 PM
hadris
Nov 14, 2016 10:36 AM
gs4bkny
Mar 25, 2015 09:03 PM
heyarms
Oct 28, 2012 08:32 PM
ChantalB79
Jan 26, 2012 02:58 PM
