Doing a muffler delete
Old Sep 6, 2009 | 05:21 PM
  #31
LexGX's Avatar
LexGX
Can someone post pics how to remove the mufflers? Are the bolts easy to take off and did you have to use any lubricants to loosen the bolts? I'm tempted to take it to the shop and let them do it but if i can do it for free then i should right? I just don't know where to begin.
Old Sep 6, 2009 | 05:30 PM
  #32
Li Ls4's Avatar
Li Ls4
there are two bolts on each side where the pipe from the muffler connects to the pipe from the resonators. 3 out of the 4 bolts came of fairly easy for me. the 4th i had to shave off caz it was stripped.
after that go to the mufflers hangers. there are two bolts holding the the hanger, take those to bolts out and there u go no more mufflers.
all and all id say it took me about 20 min to do all this. very easy and quick job
Old Sep 6, 2009 | 05:41 PM
  #33
LexGX's Avatar
LexGX
thanks, i will give that a try this weekend. I might need a couple of jacks for this. How far did you lift yours so that it was comfortably performed?
Old Sep 6, 2009 | 10:34 PM
  #34
Li Ls4's Avatar
Li Ls4
not all that high, the car was lifted just enough for me 2 lay under it.
Old Sep 6, 2009 | 11:18 PM
  #35
LexGX's Avatar
LexGX
I'm going to give it a go next weekend when i get home from school. Hopefully i won't mess up anything. I'll spray the bolts down with wd-40 first, let it sit for about 5 mins and then get to working.
The hangers that you are talking about, it is what that is holding the mufflers in place right? and the two bolts on each side of the muffler is what that is connecting the muffler to the rest of the exhaust?
Old Sep 7, 2009 | 01:44 AM
  #36
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
what year is the LS? 2nd gen uses 1 bolt per side in a clamp. PB blaster, not WD-40 (which isnt a penetrating lubricant) works best on loosening that crap up.
Old Sep 7, 2009 | 02:16 AM
  #37
Do.Man's Avatar
Do.Man
easy to take off on mine. just put some muscle into it.
about 20 mins seems right.
Old Sep 7, 2009 | 12:27 PM
  #38
JBrady's Avatar
JBrady
First pic is the center muffler/silencer section from 1995-2000 LS400
Next is view of rear exhaust with car on rack without wheels.
Next is closer look at dual pipes from center to rear muffs
Next is closer and then the actual clamp(s)
Earlier models are very similar except use 2 bolt flanges instead of the 1 bolt band clamp.
Attached Thumbnails Doing a muffler delete-silencer-assembly.jpg   Doing a muffler delete-im000411.jpg   Doing a muffler delete-im000412.jpg   Doing a muffler delete-im000413.jpg   Doing a muffler delete-2nd-res-to-rear-muf-clamp.jpg
Old Sep 7, 2009 | 12:44 PM
  #39
JBrady's Avatar
JBrady
Here is the hanger at the back of the car at each muffler. I use locking pliers to grab the outside rubber O ring hanger and pull it off the hook and it can stay on the muffler. From there the other rubber O ring can stay on the car.
On the years with the band clamp 95-00 each outlet from the center silencer section has a rolled edge to make it easier to slide the pipes together. This creates an unneccesary flow obstruction that I used locking pliers/patience/skill to gentle un-do creating a straight flowing part with no lip. The pictures show the stock outlets with 48mm outside and only 40mm inside due to the lip.
After removing each rear muffler (10min on my car) the result is simply nothing after the center silencer section. This is still surprisingly quiet with a sound more like a stock V8 truck exhaust that is silent at cruising speed.
Attached Thumbnails Doing a muffler delete-im000713.jpg   Doing a muffler delete-im000714.jpg   Doing a muffler delete-silencer-outlet-od-48mm.jpg   Doing a muffler delete-silencer-outlet-40mm.jpg   Doing a muffler delete-both-muf-out-lookg-forward.jpg
Old Sep 7, 2009 | 06:48 PM
  #40
TBone12's Avatar
TBone12
I did just what you did jbrady when removing the rear mufflers from my '96 ls excpt the lip thing, and it was not as loud as i expected. i havent extened straight pipes to my bumber yet cus i dont know if i will keep it like that or do someting else. But in all it was realy easy took about 15 min
Old Sep 12, 2009 | 03:30 PM
  #41
LexGX's Avatar
LexGX
Thanks PD. I'll get some pb blaster and use that instead of the wd-40. this previous week i've been busy with school and i'm not feeling too well this weekend so i might be doing this next weekend instead.
Old Sep 12, 2009 | 03:33 PM
  #42
LexGX's Avatar
LexGX
thank you jbrady for posting these pics. This has helped me tremendously and will make it a lot easier for me when i get to do this next weekend.
Old Sep 12, 2009 | 03:36 PM
  #43
LexGX's Avatar
LexGX
Oh and i have a 94' ls400 by the way.
This is my plan for the exhaust mod. Removing the two rear muffler and see how it sounds. If its still too quiet for me then i'll remove the center muffler. If then its not loud enough, what i'll do is add dual magnaflow mufflers.
With adding the magnaflow mufflers, do yall think its necessary to remove the center muffler?
jivoz123
Performance
Jun 20, 2023 11:00 PM
eicca
Performance
15
Sep 2, 2016 09:58 PM
Patrician
Dec 25, 2012 07:21 PM
menty
Jan 28, 2009 06:42 AM
d1drift
20
Dec 3, 2006 07:08 AM
