stiff steering problem
Old Apr 14, 2009 | 05:13 PM
brae410's Avatar
brae410
Question stiff steering problem
hello to everyone i'm new here. I have a 1993 ls 400. I took it to get inspected and found out that i need a rack&pinion to pass because it was leaking very badly. So I purchased a aftermarket one and had it put in by a very good mechanic and my steering is a lot stiffer than it was.I went from steering with one finger to one hand sometimes two. When i turn corners it returns slow, I have to help it back. The mechanic said he thinks the inside of the rack is bad. By the way he flushed it completely two times. he checked it over and nothing is leaking. I contacted the manufacturer of the rack and they told me that the steering pump might be bad. they said that the pump should put out over 800 psi. I will be doing this soon as I get paid. Any suggestions would help. Oh by the way, when I purchased the car the pump was very whiny and still is but my mechanic said that its not the pump because it was working with the old rack. What are the possibilities, should I just switch the rack out and hope it was defective or try a new pump, or could it be the poer steering module, or......what could it be? I'm lost!!!!
Old Apr 14, 2009 | 07:34 PM
cation's Avatar
cation
Did your mechanic plug back in the solenoid on your rack? Not plugging this back in will cause VERY heavy steering. Don't ask me how I know... It can be seen in the first pic in this thread:
https://www.clublexus.com/forums/ls4...ystem-diy.html
Your pump whine is due to air in the system, probably due to a bad o-ring on the bottom of the fluid reservoir. Pump whine won't necessarily cause heavy steering although enough air in the system can, but not as you describe. Make sure you have enough fluid in the system too.
Report back on whether or not the solenoid is unplugged or if your new rack even has one.
Old Apr 15, 2009 | 07:21 PM
brae410's Avatar
brae410
I will see tomorrow and report back
Old Apr 15, 2009 | 09:40 PM
E46fanatic's Avatar
E46fanatic
I had this problem on my car about a month ago, i changed the rack, pump and the pump belt, it went smooth but it would stiff sometimes, problem was, there was a big piece of dirt in my pump hose and once i cleaned that out along with some power steering oil, wheel spins with 1 finger. Good luck!
Leines
RX - 1st Gen (1999-2003)
Feb 10, 2015 06:49 AM
kellyrene
Mar 4, 2014 09:47 AM
jdub20tx
Aug 8, 2012 06:29 PM
lexrod6
Jan 16, 2012 03:26 PM
