Reasonable Cost? Transmission Pan Gasket Seal
Is $375 a reasonable price for replacing a leaking trans pan gasket? The transmission fluid would be drained, not flushed. ls400 1st gen. thanks.
sounds a little high, shouldnt be more than $300 imho including the fluid at $65 an hour.
u can soooo easily do this in ur driveway...hell in the street also. cple bolts, some RTV sillicone, some new oil and ur straight.
Yeah this can be done on your own for less than $20 provided you have the correct tools.
10mm socket, extension, socket wrench, and a torque wrench. Easy. |
^exactly, i did mine in like an hours and a half. 20 dollars gasket and filter, and three bottles of tranny fluid. total cost=35 dollars ish.
Originally Posted by cation
(Post 4315774)
10mm socket, extension, socket wrench, and a torque wrench. Easy. i will call around to get some other quotes... |
Originally Posted by margarita
(Post 4316819)
yeah, that's what a thought after looking at that pictorial in lexls. doesn't look that much more complicated than changing engine oil (i've never done either). i would try this in a heartbeat, but no good place to do it. i've never jacked up a car in my life either, and would have to buy the tools, etc.
where in cali are u?? see if anyone is willing to help u in the regional forums. just pay for lunch or dinner and a 6pack and im sure they'll do it.
I could help you out if you're in the Bay Area, within reason.
The tranny pan on these is easy to pull, but if RTV silicone was used to seal it, it's a pain to break the seal. |
(Post 4316868)
Yeah try to shop around at a mom-n-pop type import shop that are familiar with working on Lexus automobiles. $300 for this job is WAAAYYY too high. I would expect you could get away with <$200.
Originally Posted by nthach
(Post 4317897)
(Post 4317937)
nice offer, thanks, but i'm in LA. i have a few other things i need to do, so can probably negotiate it down to a very reasonable amount with an indie mechanic (i have some leads). i can't believe i was quoted that high. maybe they made a mistake. oh well...
Originally Posted by Vdog15
(Post 4319110)
Im in LA also, in fact im about to do mine as I type this. So RTV instead of a gasket is what I see posted. Im not sure about the RTV, think I feel better with the gasket. Cant find one without getting a trans filter also.
i found a really great blog that shows step by step (realize you may not need any instruction) for changing out the fluid, and also how to non-machine flush. go to my other recent thread "transmission: drain or flush" (titled something like that) and the links are there. |
The Purolator filter (screen) kit comes with a high quality, reusable gasket. If you ever have to go back in there (for a solenoid replacement for example), it will make life easier that's for sure...the pan on mine was REALLY stuck on there with red RTV.
(Post 4317937)
