Axle, hub or rotor?
Old 02-18-09, 07:59 AM
deanbrown
deanbrown's Avatar
Default Axle, hub or rotor?
I have symptoms of distorted front rotors, but only after driving several miles (around 20 I would say). When the car is cold, the brakes are smooth as on a new car.
Is this something to do with the front axle heating up after a while? Or the hub assembly? I'd hate to change the rotors again if its nothing to do with them.
I changed them around 30K miles ago and it helped, but it was not long before I started feeling the pulsing on heavy-braking.
Any ideas anyone?
96 LS400 207K
Old 02-18-09, 09:12 AM
steveski
steveski's Avatar
So when stopping cold the front rotors do not pulse through the pedal and steering wheel does not shake?
As it warms up the pedal pulses and steering wheel shakes?
Old 02-18-09, 11:05 AM
trukn1
NELOC Mod
trukn1's Avatar
I pretty much have the same symptoms on my 92. Pedal pulses when stopping. Rotors are only a year old and have already been checked for warpage, tires have been balanced (hunter 9700),and bushings are Daizens. Know that I need a strut rod, but this is about the only thing left(up front) that I haven't changed. Would a bad strut rod cause some vibration while driving also? I get a slight vibe while driving. I don't have the shake in the steering wheel but can def feel it in the pedal. Can most def feel it when driving highway slowing for a ramp, not so much just driving around the city. Any thoughts??
Old 02-18-09, 11:59 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
yeah could be a dead strut rod bushing...
Old 02-18-09, 12:19 PM
trukn1
NELOC Mod
trukn1's Avatar
Thanks Pure.
dean,, Didnt mean to thread jack. My symptoms seemed similar to yours. Please give some more detail on what is going on with your ride as Steveski suggested.
Old 02-18-09, 12:46 PM
deanbrown
deanbrown's Avatar
Yes, that is almost correct. Seems like the entire front of the car shakes, not just the steering wheel. Never noticed the pedal do anything though.
Old 02-18-09, 03:13 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Go ahead and check your bearings to see if they are shot by jacking up the car, and pulling back and forth on the wheel in the 12th and 6 o'clock position. If you can hear a slight click, your bearings are shot.
naquin123
05-14-21 05:24 PM
Eds98LS
25
05-07-13 06:21 PM
JDMis350
10-07-12 12:54 PM
beaterKU
Suspension and Brakes
11-28-05 06:32 AM
shikbas
08-15-04 06:44 PM
Quick Reply: Axle, hub or rotor?
