DIY Coolant Temperature Sensor change (PICS)
Old Mar 29, 2009 | 12:31 PM
  #46
KingNasGS4's Avatar
KingNasGS4
not noticing any significant change in MPG as yet
Old Mar 29, 2009 | 02:58 PM
  #47
jcrome04's Avatar
jcrome04
Maybe nothing significant.. but any increase at all??
I just filled up so the MPG test begins now
Old Mar 29, 2009 | 05:44 PM
  #48
vietunit's Avatar
vietunit
Forget MPG, with my driving it's gonna suck. I'm looking forward to the acceleration =]
Old Mar 29, 2009 | 09:20 PM
  #49
KingNasGS4's Avatar
KingNasGS4
i have to completely fill up and do the test but
with my half tank, im at the quarter mark now and havent noticed anything much different from before... the miles seem to be close to before i changed the sensor
but like i said i have to do the full fill up then do the normal testing method
so im not gonna pass judgment yet
Old Apr 5, 2009 | 10:50 AM
  #50
KingNasGS4's Avatar
KingNasGS4
after I changed my coolant temp sensor, the car idles a lot higher from a cold start. when in neutral or park even after the engine is hot. it idles like the car is still cold.
BUT if i turn off the car and turn it back on, the idle goes to normal level and idles like the car is warm.
it seems like the sensor gives the initial cold start reading ALL the time.
I'm starting to wonder if its because I used a sensor from autozone the computer is getting a wrong reading and thinking the car is cold? I may have to buy one from lexus and see the difference
NOTE TO ALL, BUY THIS PART FROM LEXUS!!! not from autozone or strauss!!!
Old Apr 5, 2009 | 02:31 PM
  #51
jcrome04's Avatar
jcrome04
Always go OEM with important parts like this!
Old Apr 6, 2009 | 07:46 AM
  #52
cation's Avatar
cation
Bought mine from Autozone. It works fine for me.
Old Apr 7, 2009 | 01:53 PM
  #53
KingNasGS4's Avatar
KingNasGS4
i saw in another thread a member had the same problem as me.
Old Apr 7, 2009 | 02:25 PM
  #54
avalon42's Avatar
avalon42
Ok bud, did you finally replace yours with a LEXUS/TOYOTA brand one? If you didn't, stop blasting the aftermarket one until you VERIFY that it is the culprit.
Me and a few others here are having good luck with the Autozone one...so far.
Old Apr 8, 2009 | 11:19 AM
  #55
jcrome04's Avatar
jcrome04
My MPG is MUCH noticeably better
And power delivery...... WOW
Old Apr 8, 2009 | 12:10 PM
  #56
vietunit's Avatar
vietunit
Hows the power delivery? Planning to do these on the weekend. Hope me luck.
Old Apr 8, 2009 | 12:45 PM
  #57
polobai's Avatar
polobai
Did mine, didnt notice much of a difference from a half tank. I used an OEM sensor-and have the higher idle as well-but it drops down to normal on its own after 5 mins.
Old Apr 8, 2009 | 01:49 PM
  #58
jcrome04's Avatar
jcrome04
apparently the power delivery is wow?
Old Apr 8, 2009 | 07:16 PM
  #59
avalon42's Avatar
avalon42
Using OEM or Autozone, jcrome? Apparently there is a long list of dis-satisfied customers.
Old Apr 8, 2009 | 11:09 PM
  #60
jcrome04's Avatar
jcrome04
OEM FTW
