UGH is my LS offset wrong?
Old Jul 17, 2008 | 09:57 AM
ryanSC300lover's Avatar
ryanSC300lover
Originally Posted by ryhi
if your wheels have a dual lug pattern, you wont be able to run anything less than 25mm.
they are original 5x114.3 from the factory. not redrilled or anything.
Old Jul 17, 2008 | 09:58 AM
ryanSC300lover
Originally Posted by steveski
Ryan,
Consider I run +35 offset on a 9.5" rim. I have 285 series on them with 2" drop. I had to modify fenders to avoid rubbing. I did not want to stretch the tire though. I think you will be happy with the spacers. Even if you have to modify the fender by rolling or cutting it will look good
Appreciate the help buddy! I think best think would be put the wheels/tires on Friday, and see how it looks, and order spacers after that. What do you think?
Now I gotta figure out what is the best tire option. Sigh.
9 front
10.5 rear
Old Jul 17, 2008 | 11:49 AM
steveski's Avatar
steveski
If you don't want to stretch the tire you could put a real sneaker on the rear. I could go to a 295 on my 9.5" wheel so I would imagine a 295 on a 10.5" wheel would look pretty narly. And with your offset it would pretty much fill up the fender. Up front I run 245 series on an 8.5" wheel and they are stretched just a little. I dig the look of my staggered fitment - it is pretty extreme - definitely not your normal LS.
For tires I recently swapped to Toyo Proxes T1R and I like them better than the Nitto NT 555's they replaced. They cost a little more and ride better.
Old Jul 17, 2008 | 11:56 AM
ryanSC300lover
Thanks for the info.
My tire shop is recommending the following:
245/35/19
265/30/19
Old Jul 17, 2008 | 04:27 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
a 245/275 f/r setup
Old Jul 17, 2008 | 04:28 PM
ryanSC300lover
Originally Posted by PureDrifter
a 245/275 f/r setup
did a rear 265
hope that will be work
did go with ur rec of 245 front
will have pics tomorrow
RC5
RC F (2015-present)
23
Apr 19, 2019 05:24 AM
SpecialK80
Apr 29, 2016 12:08 AM
ZSC3
IS - 1st Gen (2001-2005)
Jul 8, 2009 02:17 PM
iamkhanz
Jul 7, 2007 06:47 AM
GS4
Wheels, Tires & Brakes Forum
Sep 6, 2004 06:31 AM
