My LS... pictures inside.
Your camera took such a sharp photo the car almost looks like a model
i just put my old g35 coupe 18" rims on my dads 99 Ls400...They fit perfectly they didn't even need the hubcentric rings...i bought some but i didn't need to
use them...All i had to buy were new lugnuts...the 18s cleared my brembos and they cleared the ls' calipers easy...the +30 offsets are perfect, they sit flush
with the fenders...just posting in case anyone was curious if they would work.
He's right.
toyota has 60.1mm bores and nissan is 66.1mm bores , so their is a 6mm gap. The spacer you need are hard to find but i have the same ones for my OZ's.
zero whobble and they ride smooth...
u are very likely to break/snap a wheel stud and watch one of ur wheels go flying past you while your driving if u dont have hubrings...
the point of hub rings isnt to CENTER the wheel, the weight of the car is supposed to be on that central hub, hence all toyota cars are known to be HUBCENTRIC as opposed to the lugs taking the full weight of the car (known as lugcentric)
where did you order yours from...i ordered mine from 1010tires.com...they are the 66.06/60.1...these will work right?
