no electrical power until I rev the engine ??????
Old 04-01-07, 12:08 AM
sonbum1
sonbum1's Avatar
Default no electrical power until I rev the engine ??????
when I start my car none of the gauges work no power anything unless i rev the engine up really high then all the electrical things come on. ANy ideas what is going on? I just replaced the battery, I have double checked all the fuses.
Old 04-01-07, 12:40 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
have the alternator tested.
also check all the major grounding wires.
Old 04-01-07, 12:51 AM
sonbum1
sonbum1's Avatar
I'm having the Alternator testd tomorrow, good idea with the ground wires!
Old 04-01-07, 09:19 AM
Boyscout
Boyscout's Avatar
also check the spring on your idler bearing. if it is shot there wont be enough tension on the belt, thus not turning the alternator. the tension in the belt would increase a bit when you rev your engine, which may be why you get power when you rev it.
Old 04-01-07, 04:49 PM
sonbum1
sonbum1's Avatar
Problem solved.....it was an alternator fuse or relay, that I had checked prior to changing the battery, it must have shorted during the battery change.
YoungNas
16
12-10-18 04:13 AM
TriniLex
ES - 5th Gen (2007-2012)
25
12-21-15 02:17 PM
steveo81
09-15-08 10:56 AM
twizted
Performance & Maintenance
01-29-07 04:50 PM
Quick Reply: no electrical power until I rev the engine ??????
