Pull to right LS 400
Old 12-29-06, 05:19 PM
stan774
stan774's Avatar
Default Pull to right LS 400
I have a 1992 LS 400 that pulls to the right. Alignment seems ok.
Non air shocks, all components in suspension system are fine and tight per lexus mechanic. Alignment is dead on.
New dunlop tires 205-65-15.
Recent new tie rod ends.
No matter where we move the tires the car pulls right. Mechanic says tires, tire shop says suspension.
Any suggestions?
Old 12-30-06, 03:09 AM
RA40
Super Moderator
RA40's Avatar
Welcome to CL.
Jack the car up and spin each front wheel and see if there is any drag present. May be a stuck caliper causing the brake pad to slightly touch the rotor or perhaps a wheel bearing issue.
The alignment may work out but if there are other worn suspension components, it may be a contributing factor. I've had alignments where it was supposed to be in spec but wasn't. Very few shops IMO nail it. I can count on my hand the number of alignments that were really good. The rest have been so-so to almost adequate.
Some suspension components cannot be detected by a push-pull test or visual. If it has lots of miles, it is highly probable it is worn or beginning to go out of spec.
Road crown...also has a part so most roads will eventually pull the car right.
Hope you find it.
Old 12-30-06, 07:27 AM
stan774
stan774's Avatar
Thank you! I will checkyour suggestions. It pulls right over the crown.
Old 12-31-06, 10:04 AM
pito
pito's Avatar
Well I know my car pulls and it is because of my worn strut rod bushings. Worth a try??
nks979
IS F (2008-2014)
13
01-13-17 11:02 AM
Bhasho
04-24-13 10:54 AM
Shinobiend
Suspension and Brakes
08-17-11 09:12 AM
suloh
Maintenance
10-17-05 08:36 AM
Quick Reply: Pull to right LS 400
