Lowering Air Suspension
BTW,
If anyone has the HyperRev for the Celsior....there are some really cool suspension controllers for the air suspension. Several companies make them and you can set the height at each corner along with adjusting the damping on the shocks.
Any importers out there to get this stuff? HKS made a cool TEMS suspension controller for the MkIII Supra...years ago. I have this HKS controller on both my Supra's.
Like Dave said, there are full air suspension controllers available in Japan...Blitz, R-Spec, Hilltop, Field, etc... they all make 'em..
R-Spec supposidly has one out for the new LS430 but I have yet to see the unit...
oh that sounds better than for me trying to do it manually. do you know if you guys can get the part for me? or a shop that will import it? i would like to get a controller instead. thanks for that info
Healerhand,
Looking at the service manual, I think you would want the wheels on the car as you adjust the height. My suggestion is this....I have these 6x6 blocks of wood in the garage that I use to place under tires when I have a car jacked up. I would place 4 of these blocks under all the tires...set the car down on the blocks......turn back on the auto ride suspension...then you would have room under the car to adjust each suspension rod. Take measurements before and during to see what happens.
FatherTo1
Jul 22, 2017 08:37 AM
