1999 ls400
Old Dec 10, 2024 | 09:15 PM
FB6244's Avatar
FB6244
4th Gear
Default 1999 ls400
I have a defective front suspension airbag and would like to convert to coilovers. Can I leave the rear airbags and just convert the fronts? Also looking for a recommendation on the best bang for the buck without breaking the bank. Thanks
Old Dec 11, 2024 | 08:50 AM
CELSI0R's Avatar
CELSI0R
I doubt you can do that. The system is going to get confused and continue trying to air up the front until the height level sensors are correct. A custom air ride controller would probably help there, but at that point you're better off investing in higher quality coilovers/struts
Your best action is likely to convert the whole car and disable the air suspension
Old Dec 11, 2024 | 09:20 AM
FB6244's Avatar
FB6244
4th Gear
Thanks
Old Dec 12, 2024 | 11:20 AM
timmy0tool's Avatar
timmy0tool
agreed here. trying to run convention and air simultaneously will be more trouble than it's worth just doing the full conventional conversion in the first place.
NickE917
Feb 5, 2024 07:07 AM
yoitskenn
Oct 21, 2017 04:43 PM
slamgrayls
23
May 20, 2017 02:46 PM
Fre831
Aug 27, 2012 02:14 PM
