Remote start
Old Sep 23, 2024 | 08:00 PM
Billy86's Avatar
Billy86
Default Remote start
How hard is it to install on 98 ls400
Old Sep 24, 2024 | 10:21 AM
timmy0tool's Avatar
timmy0tool
i've heard it done before, but it's not as simple as it appears. the key itself disables the factory immobilizer once you insert the key in the ignition (but no need to turn it - you can see the security light stop blinking upon insertion).
i've seen a hidden key under the dash to trick the immobilizer to seeing it, then it can be started remotely afterwards. it's called a transponder bypass:
https://www.walmart.com/ip/Transpond...ired/630977661
of course you will lose the security of the factory immobilizer after doing this (where someone can just jam a screw driver in the ignition and start the car) so make sure you have another immobilizer as part of the aftermarket alarm system which i assume is part of the remote start.
Cooker883
Jun 23, 2023 04:34 PM
is500le
IS 500 (2022-2025)
Jan 12, 2022 11:08 AM
DK Audio
37
Jan 22, 2010 03:59 PM
