Ls 400 1992 odometer not working
Hello everyone, I have a LS 400 1992 with 162k miles and when driving in town without highway odometer does not work at all and trip meter works correctly. When driving on highway odometer begins to work perfectly fine and correctly. What could be the issue ? Speed sensor ?
Thanks
forgot to mention that after highway ride it give TRAC LIGHT
Thanks
Does your speedometer work properly?
How do you know that the trip meter does not work correctly?
If the speedometer and trip meter work but the odometer is intermittent, it could be the gear for the odometer is worn
https://us.lexusownersclub.com/forum...-less-than-10/
https://www.clublexus.com/forums/ls-...r-service.html
for trip I was going some where by the maps and compared the distance that in maps and what the tripe meter showed after the drive
My mistake I just did it again and it showed same thing as maps
No worries, sounds like it's potentially your odometer gear then, which is a known problem for 1990-1992
Tanin Auto sells the gear and also a cluster repair service
https://taninautoelectronix.com/prod...odometer-gear/
https://taninautoelectronix.com/prod...luster-repair/
I would suggest to remove your cluster and inspect the odometer as a next step
Please check this video starting at 7:24. All other steps are not relevant to the cluster.
