Lexus 2000 LS400- need a new under engine cover
Subscribe
Jan 7, 2024 | 08:01 AM
I have a 2000 LS400 and need a new under engine cover part 51441-50070 I have looked every where . Would I be able to fit the 1997 part 51441-50050 in place
Reply 0
Jan 7, 2024 | 10:15 AM
I believe there was a recent post on this topic and the '97 belly pan is a close fit, not exact. Look for a recent post a month or two ago IIRC.
Reply 0
Jan 7, 2024 | 08:14 PM
Thanks I have ordered the 1997 version and will let you know how it fits.
Reply 0
Jan 17, 2024 | 02:15 AM
Update I received the cover for the 1997 LS400 and my Shop install today , It DOES NOT FIT , not even close . Back to searching again.
If any one has one please let me know
Thanks
Reply 0
Jan 17, 2024 | 10:27 AM
Quote: Update I received the cover for the 1997 LS400 and my Shop install today , It DOES NOT FIT , not even close . Back to searching again.
Thanks
I don't think the body shop tried hard enough
This is the thread others were referencing, which was also recently created. Same issue with a 99:
https://www.clublexus.com/forums/ls-...l#post11628287
The owner ended up using the 95-97 cover successfully, leaving 2 bolts unused.
Reply 0
Jan 18, 2024 | 10:57 AM
sure it's not 100% bolt on, but it should still somewhat work.
Reply 0
Feb 3, 2024 | 09:40 AM
I had a different Shop try the 97 engine lower cover on my 2000 LS400 and YES they installed it. The front bumper end only required a couple of hole enlargements and the rear at the oil pan fit perfectly . I had purchased a bag of fittings ,body screws etc that was a great help in the process
Reply 2
Subscribe
