1996 Celsior Side Airbag Light
2nd gear
I have a ucf20 Celsior and the side airbag light is on. I have found a lot of information on the normal airbag light but almost zero on what might be causing the side airbag light to be on. I have tried the Tc AB reset procedure using the TDCL port and it does not turn off the side airbag light. Any ideas?
Does a scan tool give more info?
Hopefully someone can post airbag diag info from the service manual. Have you physically checked to see if the curtain aribag is connected?
edit - on other Lexus models I've worked on SRS codes are read via E1 and TC
