Hello, members.
I have 2002 es300 with HID headlight and my passenger side is out. I did check those fuses for it under the hood and they are OK. Also unplugged six pin connector with five pins on the assembly and looks like there no power coming in. Any further suggestions?
Thank you!
Hello, members.
Thank you!
Sounds like you need to replace you HID bulbs (I suggest to do them in pairs....as if one is gone, chances are, the other isn't far away from failing).
Is the light on on the dashboard saying that a bulb is out?
Looks like you need the D2R size (check your owners manual to confirm.
I am a fan of Philips HID's myself....but I am sure there are many choices out there.
Let us know how you make out.
Replaced Bulb, still nothing. Got to the ballast and changed it with used one from wrecking yard, everything works now!
