Sponsored by: CARiD
Thought about 6000k hid kit I got.
Old Dec 26, 2002 | 11:27 AM
steevr's Avatar
steevr
Rominl,
Yes, I have noticed that also on my '02 RX w/ factory HIDs...the white light only comes out of the top of the reflector. Any idea what causes a fairly wide band of yellow light (almost like a fog light) to come out of the bottom of the reflector (I notice this only on the RX's...no other Lexus HID model seems to do this)? Take a look next time you see an RX. It's really also noticable when the clear housing is a little dirty and you can see the beam pattern on the housing. It looks exactly like a fog light was built-in. I'm wondering if it's something on the bulb itself or maybe Lexus did something with the bulb shield that's part of the reflector assembly.
Old Dec 27, 2002 | 01:32 AM
NoLexNoSex's Avatar
NoLexNoSex
Originally posted by steevr
Rominl,
wait...i thot RX's had HID in big reflector and reg stock bulbs in bottom half like in that horizontal strip right on bottom of headlight assembly.
Old Dec 27, 2002 | 12:16 PM
steevr's Avatar
steevr
They still have the traditional halogen projector foglight in the bottom part of the headlight assembly. The HID is in the large headlight reflector. The HID light coming out of the bottom of that large reflector (below where the bulb shield is) has a yellowish glow to it. None of the other Lexus models (other than the RX) seems to have this yellow color coming from the bottom of the HID headlight reflector.
I'll try and take picture and post it.
Old Dec 27, 2002 | 03:45 PM
rominl's Avatar
rominl
exclusive matchup
Rominl,
umm... i need to take a look at the rx to see how it's done. sounds very interesting though. maybe they design the housing very smartly to create the effect
Old Dec 27, 2002 | 03:46 PM
rominl's Avatar
rominl
exclusive matchup
umm.... that's very interesting
Old Dec 29, 2002 | 11:35 AM
steevr's Avatar
steevr
Ok, here's some pics to show you what I mean about yellow HID light coming out of the bottom of the RX reflector.
This first pic shows the beam pattern against my black garage door. Notice a yellow band of light on the bottom?...this is coming from the headlight....the fog light is off.
Old Dec 29, 2002 | 11:37 AM
steevr's Avatar
steevr
This pic is a closeup of the reflector. The scratches you see on the light housing is dirt and salt spray.
Old Dec 29, 2002 | 11:38 AM
steevr's Avatar
steevr
You can see the beam pattern on the housing on this shot.
Old Dec 29, 2002 | 11:42 AM
steevr's Avatar
steevr
Here's the final pic. This one is from the driver's side. See, I'm not crazy. So the question still is, is there something special on the bulb that's producing the yellow or is it something in the cap that's covering the bulb?
Old Dec 29, 2002 | 01:29 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
On all OEM HID setups with reflector housings you will notice that the whole reflector housing is not lit up. It is usually 1/2 - 3/4 of the top of the housing. I know with the Lexus reflector housings you can easily see that only the top half is lit up. There is a large shield keeping the light up top. Also, D2R bulbs (with the shield) are used. Try switching to a D2R and see what happens.
Old Dec 29, 2002 | 08:09 PM
steevr's Avatar
steevr
LexRX,
They are D2R's. If you look at the last picture, you'll notice the label "D2R" stamped into the plastic headlight housing.
Old Dec 29, 2002 | 09:23 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
LexRX,
You're right, they are D2R - I thought you had put in a set of aftermarket HID bulbs in your OEM housing.
I have a Phillips HID kit in my 2000 RX (OEM halogen) and I too get some yellow at the bottom of the reflector. It doesn't look the same as yours, steevr, but it is there. It appears to be coming from the bulb area itself, but it isn't as bad as yours. I'll post some pics soon.
Old Dec 29, 2002 | 09:36 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Default Warming Up
You can see that the green is not evident (or present at all) while the lights are warming up and a bluish color. I know, the lenses are dirty!
Old Dec 29, 2002 | 09:38 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
You can see from the reflection on my pants that there is a strip of greenish color between the white HID color and halogen foglights.
Old Dec 29, 2002 | 09:40 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Here is a close-up of the lens where you can get a glimpse of the green at the bottom part of the lens.
