9006 relay to OEM ballast
Old 10-02-12, 05:48 PM
mr. tetsuo
mr. tetsuo's Avatar
Default 9006 relay to OEM ballast
my LS did not come with factory HID and uses 9006 bulb for low beam. i purchased a set of retrofitted headlights that uses the OEM ballast to power D2R bulb. here is what the connector from the ballast looks like.
i tried to search for the correct relay to run (im sure i need one that runs to the battery for more power), but am not 100%.
http://www.theretrofitsource.com/pro...oducts_id=3182
will this one work? any guidance is greatly appreciated!
Old 10-02-12, 08:50 PM
chrispy
chrispy's Avatar
You just need a 9006 and either splice the wires or use wire taps into that harness. The OEM harness should be enough to power the ballasts since the car was designed for OEM HID. Just make sure the positive and negatives match up.
Auxive
05-19-16 09:40 AM
spliff
09-08-14 08:41 AM
Chuck4200
03-24-14 06:53 AM
maaloxx
Lighting
14
06-22-05 07:45 AM
likopiko
Lighting
11-02-04 06:38 PM
Quick Reply: 9006 relay to OEM ballast
