Sponsored by: CARiD
Need lighting help!
Old Apr 5, 2010 | 08:36 AM
Slvr surfr's Avatar
Slvr surfr
Default Need lighting help!
Replace the rear turn signal bulbs with led versions from Vled.com today along with the front parking lights. Turn signals look great but now they flash rapidly instead of there normal flashing speed. Do i need a different flasher or do i need a load resistor or something else. Front parking lights are not worth changing imo because They to not use the reflector usefully. Need help!
Old Apr 7, 2010 | 05:02 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
If you have LEDs for the rear turns only, then you need to add 6ohm 50 watt load equalizers...one for each turn signal.
http://autolumination.com/equalizers.htm
Old Apr 8, 2010 | 07:39 PM
Slvr surfr's Avatar
Slvr surfr
Thanks EXE! I was starting to wonder if i was crazy for asking the question based on the lack of responses. Anyway, currently i have just the rears in but the front set should be here tomorrow along with two 3 ohm 25watt load resistors. I did a lil searching on Vleds.com and found the solution. Thanks for the response anyway!
Old Jun 9, 2011 | 05:38 PM
revel's Avatar
revel
love the search function. having same issue now i have the solution. thanks.
Old Jul 14, 2011 | 01:53 PM
hairlifter's Avatar
hairlifter
Hi, I need a replacement offside headlight computer for my Lexus 450h GS, year 2006 any ideas without paying a mortgage money for a new one/hairlifter
tudank
Apr 7, 2017 01:02 AM
Slvr surfr
Apr 5, 2010 08:34 AM
LtunedG
Mar 4, 2010 10:15 AM
