Lamp Replacement Guide
Check out the SYLVANIA Lamp Replacement Guide.
Here's the part numbers for cross reference. Low beam headlamp Part number = 9006 High beam headlamp Part number = 9005 Parking light Part number = 168 Front turn signal Part number = 7440 Rear turn signal Part number = 7440 Tail light Part number = 7443 Stop light Part number = 7443 High mount stop light Part number = 921 Fog/Driving lights Part number = 9006 License plate Part number = 168 Back up light Part number = 7440 Front sidemarker Part number = 194 Rear sidemarker Part number = 194 Glove box Part number = 74 Dome light Part number = DE3175 Step/Courtesy light Part number = 2825 Enjoy...:D |
ya, i used the very same thing for changing my bulb's. Very useful
RX300 sidemarkers
99 RX300....three side markers out of 4 out. Any clue as to bulb access??
The Owners Manual/Section 6-4/Replacing Light Bulbs page 301 even calls for 7440 not 7440A. |
Originally Posted by Wheel0217
(Post 1179903)
https://www.clublexus.com/forums/rx-...ker-light.html In this post he has included a DIY Side Markers lights RX300.pdf. |
Sorry for bringing back such an old post but is there a special technique to get at that front "parking" light. I think that is what they call the top most light closest to the side of the car. Also is there a trick to getting at the fog light? A screw appears to be there that blocks you from twisting it out and its somewhat blind down there. I tried unplugging what seemed like the power cable but i don't want to break anything going on blind.
Bulb information is incorrect...
Sorry for bringing back an even older post but I believe some info here is incorrect.
Earlier the post states that the tail light and the stop light use the same bulb (7443), I believe this is incorrect. Bulb 7443 has two filaments while bulb 7440 has a single filament. The two filament bulb is used so that the same bulb that is on when the lights are on can also be used when the brake light is triggered. How does it perform this dual function? By having 3 wires on the harness; one common wire and then one that is for normal operation (lights) and one that is for braking. If you look at the wiring harness for the lights you'll see that the tail lights harness only has two wires while the brake light harness has three wires; so the two wired harnesses (tail lights) are used with a single filament bulb (7440) while the three wire harnesses are used with the dual filament bulb (7443). This was a pain when I switched my 2000 RX lights to the more updated look of the 2002+ lights from a Pick-A-Part and found that the previous owner had the incorrect bulbs installed and they had melted some of the insides of the lens. Plus the bad brake light indicator will light if the bulbs aren't correct. Hope this helps someone else out. By the way, to get at the front "parking light"/side marker this is how I do it: (from memory) (You don't have to remove the wheel - I didn't even have to turn it and I have 18" wheels.) Remove the two 10mm bolts in the wheel well keeping the liner in (one near the top front and the other near the bottom front) Remove the 2 or 3 phillips screws one the fender near the front up to the center of the wheel well holding that side of the liner in. Remove the 10mm bolts under the vehicle holding the liner in place there. You can now adjust the liner (pull out the front edge by the fender) so that you can get your hand behind the side marker. The bulb is in at an angle pointing towards the front of the car not flush pointing towards the side of the car like the rear side marker, so when you twist the bulb assembly counter clockwise to remove (you'll be doing this blind) keep that in mind. |
Originally Posted by rdaught
(Post 11220727)
Earlier the post states that the tail light and the stop light use the same bulb (7443), I believe this is incorrect. Bulb 7443 has two filaments while bulb 7440 has a single filament. The two filament bulb is used so that the same bulb that is on when the lights are on can also be used when the brake light is triggered. How does it perform this dual function? By having 3 wires on the harness; one common wire and then one that is for normal operation (lights) and one that is for braking. If you look at the wiring harness for the lights you'll see that the tail lights harness only has two wires while the brake light harness has three wires; so the two wired harnesses (tail lights) are used with a single filament bulb (7440) while the three wire harnesses are used with the dual filament bulb (7443). This was a pain when I switched my 2000 RX lights to the more updated look of the 2002+ lights from a Pick-A-Part and found that the previous owner had the incorrect bulbs installed and they had melted some of the insides of the lens. Plus the bad brake light indicator will light if the bulbs aren't correct. Hope this helps someone else out. By the way, to get at the front "parking light"/side marker this is how I do it: (from memory) (You don't have to remove the wheel - I didn't even have to turn it and I have 18" wheels.) Remove the two 10mm bolts in the wheel well keeping the liner in (one near the top front and the other near the bottom front) Remove the 2 or 3 phillips screws one the fender near the front up to the center of the wheel well holding that side of the liner in. Remove the 10mm bolts under the vehicle holding the liner in place there. You can now adjust the liner (pull out the front edge by the fender) so that you can get your hand behind the side marker. The bulb is in at an angle pointing towards the front of the car not flush pointing towards the side of the car like the rear side marker, so when you twist the bulb assembly counter clockwise to remove (you'll be doing this blind) keep that in mind. Old threads don't bother me at all. It's not like helpful goes obsolete and sometimes people want a fresh look on older topics especially current availability of parts, tools, and techniques. |
Sorry, I got it wrong. Must have been half asleep...
(Post 11220737)
Good catch!
Old threads don't bother me at all. It's not like helpful goes obsolete and sometimes people want a fresh look on older topics especially current availability of parts, tools, and techniques. My bad.... . |
