Can someone put up pics what exactly it is we are supposed to be checking and resealing.
I 2nd that...yesteray it rained and my driver side headlights and inner lights both have condensation! Pics Please! do you have to take off the headlights in order to seal these O rings?
another question....today my head lamps that had condensation both city and head lights dried up....however a couple hours after leaving car out in the sun condensation came back! any ideas? I've been thinking about swapping out headlights but finding stock HID units seem to be extremely pricy! I never had issues till I recently changed my D2R bulbs...everything seems to be sealed up properly and vents are clear...no idea what's going on...PLEASE HELP!
There is metal bracing over those levels and most screws to get the cover off on my GS430, I guess you have to take all these metal pieces off just to take all the screws off and open the plastic top to try to reseal the plastic cover. I was hoping you could just get at the screws but with the metal blocking a couple it is going to be much more of a pain to take all those metal pieces off. Anybody have any issues when taking the metal bracing over the levels off?
Yeah, I know what you mean. I wish I would have done this before I re-mounted the headlights. So is this where the moisture/condensation coming in from?
Sorry guys, I dug through my old files to see if I could find the pictures but for some reason they are not there :/.
The idea is to pretty much seal this opening. Take the cap off, put some epoxy/silicone in the channel where the rubber/foam gasket sits and then re-install the cap.
Remove the cover, yours might look a bit different as some headlights had bigger covers.
Put RTV silicone in the channel, as shown.
Put the cover back on, DO NOT PRESS IT.
tighten the screws gradually, you may see some silicone ooze out of the sides.
Note: this will only make sure that water doesnt get inside the headlight from this particular opening. It wont rid the moisture already present inside the headlight. You may want to throw in a pack or two of 5~10 gram weight silica gel desiccants.
JnC: Great photos and simple DIY. Since the heavy rains these past 2 days in Norcal, my headlights have lot of moisture in the headlights. I resealed the headlights well so I suspect it's coming from that clear plastic leveler thingy. Mine is actually warped a bit because whoever did the retro for the previous owner baked the headlights with the plastic leveler cap still attached.
The problem is for the 2GS guys is the stupid metal bracket in the way.
