Sponsored by: CARiD
need help with size...
Old Aug 30, 2007 | 11:52 AM
thanhvu's Avatar
thanhvu
Default need help with size...
i took this picture from the buy/sell forum...so if the owner wants me to remove it i will..
for those who have open ur headlights....what is the size in MM of the circle in the DRL area....if anyone know please help...thanks...
Old Aug 30, 2007 | 01:18 PM
2slow's Avatar
2slow
Why does the size matter anyways? are you trying to find out what bulb can fit in there?
Old Aug 30, 2007 | 03:26 PM
thanhvu's Avatar
thanhvu
NOPE!...trying to put this there...
Old Sep 8, 2007 | 11:20 AM
thanhvu's Avatar
thanhvu
no one knows??
Old Sep 8, 2007 | 11:23 AM
DarKnight's Avatar
DarKnight
That's kind of difficult to answer because it's not exactly round. But it's about 4.5" from top to bottom and about 5" from side to side. Hope that helps.
Old Sep 8, 2007 | 12:36 PM
chrispy's Avatar
chrispy
Can you circle exactly what you want measured? I have headlights taken apart at home but I'm at work right now. I can find out for you.
Old Sep 8, 2007 | 01:32 PM
DarKnight's Avatar
DarKnight
I think he means the highbeam reflector bowl.
Old Sep 9, 2007 | 04:10 PM
rayy's Avatar
rayy
that looks like a pretty cool project.. update us on how it goes
Old Sep 9, 2007 | 06:17 PM
chrispy's Avatar
chrispy
I'm not sure if he means the reflector bowl, or the size of the opening on the bezels. The reflector bowl's circumference is slightly larger.
Old Sep 9, 2007 | 08:41 PM
thanhvu's Avatar
thanhvu
sorry guys for not being more specific...i outlined in yellow which i need to know the circumference of...i dunno what its called...i think its the reflector bowl because the light ring i want to get..it varies from 70 mm, 80 mm and up to 130mm...also...its where people would put their ccfl angels eyes..
Old Sep 9, 2007 | 09:07 PM
chrispy's Avatar
chrispy
I just measured and it's not a perfectly round circle. From left to right it's about 105mm. From top to bottom it's about 100mm.
Old Sep 9, 2007 | 10:27 PM
thanhvu's Avatar
thanhvu
cooool...thanks alot man...ill probably just get the 100mm so it won't be to big...thanks again...
Old Sep 10, 2007 | 12:18 AM
chrispy's Avatar
chrispy
I want to see the outcome. I hope the 100mm fits.
Old Sep 10, 2007 | 01:13 AM
DarKnight's Avatar
DarKnight
Wouldn't it be better to just measure the circumference as opposed to the diameter? Is that light ring flexible?
Old Sep 10, 2007 | 07:48 AM
tiguy99's Avatar
tiguy99
How do you plan on mounting it? Is it going to sit behind the rear edge of the GS chrome trim piece or on the front somewhere?
