ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Lighting (https://www.clublexus.com/forums/lighting-128/)
-   -   HIDs won't ignite but they're not defective... (https://www.clublexus.com/forums/lighting/277962-hids-wont-ignite-but-theyre-not-defective.html)
sorka Apr 23, 2007 04:39 PM
Got my HID conversion kit today. Before installing, decided to test the lights by assembling the ballast, harness, and bulb. Plugged into 9006 socket. Turned on headlights. Nothing. Tried the other side. Nothing. Put the original bulbs back in. They worked fine.
Next, moved to 300ZX and plugged them into the 9006 connectors. Turned headlights on. HIDs instantly came on and in about 15 seconds were just blinding. Orderd 5000K, but I could tell they were closer to 4300K. Either is fine.
Next, went back to SC400 and tried the 9006 connectors again. Nothing. Then I tried the 9005 connectors. Nothing.
My only conclusion is there is a circuit on the SC400 that is preventing power unless it detects the correct resistance.
Any ideas?
nimit1234 Apr 23, 2007 05:00 PM
turn the connector around.. it wont clip into place, but for some reason our SC's had the polarity reversed. take my word for it.. the ebay guy sent me a whole nother set bc i said this one was defective.. so i have 2 sets for the price of one =X.
sorka Apr 23, 2007 05:17 PM
Thanks. I was just coming in to say the same thing. I figured, well if there's a circuit detecting load, then the voltage would be different, but it wasn't. So I checked the voltage on my Z and noticed that the polarity was reversed from the SC. So I turned the connector around and blam.
Thanks again!
DriftNsc3 Apr 23, 2007 05:17 PM
Sorry about the lights but try what ^^^^he said. Also thier is no way the neked eye can tell the diff. from 4300k and 5000k. Trust me, I work with HIDs and headlights eveyday.
DriftNsc3 Apr 23, 2007 05:19 PM
Glad you figured that out!
sorka Apr 23, 2007 06:58 PM
I own a number of HID flashlights ranging in color temp from 4200K to 6500K. You most certainly can tell the difference.
But the reality is there's enough variation in individual lights of the same spec that there's no way to really be sure.
vg7z Apr 23, 2007 10:30 PM
The same thing happened to my sc300. However I didnt have to do no reverse polarity. I just plugged in a 9006 bulb, turned it on and it worked. Then plugged in the 9006 HID right away and it worked, and its been woprking since
cliffud Apr 23, 2007 11:44 PM
did you ever use those aftermarket 110w bulbs? those can often melt the headlight plug and this warped plug may not work well with the hid kits.
RedPhoenix Apr 24, 2007 05:53 PM
yeah isnt it weird that the SC is reversed?
