Sponsored by: CARiD
How to replace interior lights
Old Mar 22, 2007 | 07:25 PM
wxman1969's Avatar
wxman1969
Default How to replace interior lights
Ok this is probably obvious as I haven't seen it mentioned in other threads, but how do I replace the interior lights, especially the dome and map reading lights? I have a 2003 GS430. A quick inspection didn't lead to an immediate answer, and I don't want to break anything so I figured I'd ask the experts here.
Thanks.
Old Mar 29, 2007 | 12:29 PM
Teal Sc400's Avatar
Teal Sc400
Default Dome Light
Thanks.
wxman, Take a flashlight an touch & feel, by sliding your index finger a long the edge of the dome light. There will be a indentation or notch in the plastic fixture. Once you find it place a small flat head screwdriver into the notch and push forward, gaining access to the bulbs compartment. On the 95 Sc400 model the notch is centered in back of the dome light furthest from the front windshield. I hope this helps
Old Mar 29, 2007 | 02:19 PM
o2GS43o's Avatar
o2GS43o
For the GS, it's wedged in there pretty tight, so you need a small flathead, and pry it slowly... there should be 2 tabs on the both of the longest sides of the dome light...
Old Mar 29, 2007 | 07:51 PM
wxman1969's Avatar
wxman1969
Thanks for the responses. I'll give it a try, though like you said it's in there pretty tight.
Old Mar 29, 2007 | 09:16 PM
4ntvings's Avatar
4ntvings
as with most everything on the GS, take your time-patience.
Old Mar 31, 2007 | 01:10 AM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
i was wondering about the map light too i want to find a replacement for them but dont kno the replacement # for them. anyone know?
StClair
Aug 4, 2018 12:42 PM
is250jz
CL of Southern California
Feb 21, 2018 12:07 AM
RC1818
GX - 1st Gen (2003-2009)
Jan 1, 2018 08:23 PM
luxe88
May 24, 2017 05:20 AM
DP03
Jan 9, 2017 06:28 PM
