Sponsored by: CARiD
DIY LED Cluster backlighting
Old Sep 18, 2006 | 12:01 AM
tuan92129's Avatar
tuan92129
Default DIY LED Cluster backlighting
I did a search on this, but only found the bulb for a direct replacement which should be a # 24 sylvannia bulb. However, on superbright leds (scroll down near bottom) it shows only 1 category for cluster backlighting in a #74 bulb. If these come with its own twist base, will they fit in my cluster? Do i have to worry about the voltage/shortcircuiting the cluster with these bulbs? http://www.superbrightleds.com/mini-wedge.html
Old Sep 18, 2006 | 02:39 AM
datsetup's Avatar
datsetup
Some one please answer his question
Cause i also want to know i think you can use them but not sure the sc clusters are very *****y only can put sertain bulbs in there...
or you can buy them from Lextech havnt ordered anything from them yet but will be soon
Old Sep 20, 2006 | 12:39 AM
tuan92129's Avatar
tuan92129
kinda tight on $$ so I saved the cluster for later
Will post pics of led interior lights when they are installed
Old Sep 20, 2006 | 01:32 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
We've spoke about this a billion times, and the threads are there.
Nothing plug and play will work without big glaring spots in the SC cluster. The guy's with ES's can "almost" get away with it. (bigger spreaders inside, different design).
levinsoy
GX - 1st Gen (2003-2009)
May 10, 2017 07:00 AM
2GSTony
Dec 14, 2014 01:25 AM
Jafch1
Jul 21, 2012 03:53 AM
frey7190
Jun 18, 2011 06:54 AM
bleedspeed
May 10, 2011 11:45 PM
