Sponsored by: CARiD
Yellow OEM foglights
Old Sep 28, 2004 | 08:08 PM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
Default Yellow OEM foglights
how do i remove the bulb from the OEM yellow fogights???
http://img.photobucket.com/albums/v4...e/DCP02086.jpg
they are the ones closest to the grille in that one...
Old Sep 29, 2004 | 09:39 AM
siniquezu's Avatar
siniquezu
If your hand and arm fits, reach through the bumper. If not, pull the engine under cover.
Old Sep 29, 2004 | 01:38 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
the radiators in the way...there is space to do it, thats not the issue, the issue is i dont know how to get the bulb out...does it unscrew or what???
Old Sep 29, 2004 | 02:50 PM
siniquezu's Avatar
siniquezu
it's probably an H3 bulb or a 900X bulb. If it's an H3, then it's connected to 2 wires. One is part iof the bulb and should be pulled from the harness. The other wire should be pulled from the bulb. There may be a wire snapping it to lock it in place. If it's a 900X bulb twist it out.
Old Oct 9, 2004 | 03:58 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
it is an H3, i found out when i got my owners manual a few days ago. just wanted to put it in the archives.
gompka
IS - 1st Gen (2001-2005)
May 5, 2007 06:42 PM
Philly RX
RX - 1st Gen (1999-2003)
May 20, 2005 10:50 PM
