Sponsored by: CARiD
Puzzling Tail Lamp Problem
Old Jul 13, 2004 | 08:34 PM
squarehat's Avatar
squarehat
Question Puzzling Tail Lamp Problem
I have a '96 ES with a puzzling tail lamp problem. I get a tail lamp out indicator light on the dash when first turning on the lights, and going around back reveals a non-illuminated taillamp on the passenger side (the 96 ES has two dual-filament stop/tail lamps on each side). I have replaced both bulbs on each side, along with the license plate bulbs on each side (haven't touched the reverse lights or turn signals yet).
Here's the puzzling part. After about 15 minutes of driving, the taillamp out indicator goes out, AND the bulbs all work normally again (I'ved hopped out of the car with the engine still running/lights on to validate this).
What could be the issue here? Bad wiring harness on the passenger side? Or could it be a more serious electrical problem (perhaps the system doesn't get enough voltage to run all of the lamps until the alternator has been running a while, though I'm not noticing any dimming of the headlamps, or problems with the audio or climate control, nor any other warning lamps). Changing bulbs doesn't seem to do much help...
Thanks!
Old Jul 23, 2004 | 07:08 AM
Fisher503's Avatar
Fisher503
Happened on my 98 ES Change all bulbs signal rear center brake reverse!
Old Jul 27, 2004 | 12:32 PM
Blanco's Avatar
Blanco
I agree with Fisher. Sounds like you have a bad bulb somewhere. It's not totally gone, but with the right temp increase, or vibration from driving causes the connection to become good again. Swap ALL the remaining bulbs, then see where you're at.
Old Jul 27, 2004 | 12:57 PM
Fisher503's Avatar
Fisher503
Let us know what happens?
BonJecker
Feb 27, 2017 11:19 AM
lje87
Nov 16, 2013 02:01 AM
Bradwillia
Nov 19, 2012 09:50 PM
rclab1
Feb 3, 2009 05:59 PM
JayLex112
Lighting
Mar 7, 2002 11:01 PM
