IS Convertible Sporting IS F Gear @ Nürburgring
Old 07-17-12, 06:54 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
Default IS Convertible Sporting IS F Gear @ Nürburgring
Originally Posted by Carbuzz
Lexus IS F Convertible at the Ring
Japanese M3-fighter is being readied in open-top form. Lexus did one heck of a job turning the IS sedan into the IS F performance machine. But the four-door isn't the only version of the IS. There's also a two-door hard-top convertible, and as these spy shots reveal, the premium brand from Toyota is planning to F it all up, too.Spied undergoing testing at the Nurburgring, this IS F cabrio is identifiable by its new front bumper, wider wheel arches packing larger stock and a massive rear wing (possibly used for testing purposes only). Also, by the very fact that it's at the Nurburgring altogether.
The IS F sedan features a 5.0-liter V8 with direct injection to deliver 416 horsepower to the rear wheels for a 4.6-second sprint to 62. Expect the convertible to mimic these numbers, but with two fewer doors and one big folding roof. That is, assuming Lexus doesn't follow Mercedes' lead by fixing the roof like AMG did with the SL65 Black Series.
Source: carbuzz
Originally Posted by Insideline
Just the Facts:
2014 Lexus IS F convertible is caught testing on the Nürburgring.
GS-derived rear suspension is capable of offering rear steering.
Aluminum lower control arms replace stamped steel currently in use.
NURBURG, Germany — The long-rumored Lexus IS F convertible has finally been spotted testing at Germany's famed Nürburgring, but it's what's under the car that is even more exciting.
Before the camoflauged 416-horsepower V8 convertible went for laps around the circuit, engineers put the IS on a lift and forgot to close the garage bay door, giving us our first look at the next-generation 2014 Lexus IS hiding beneath the convertible skin.
The key giveaway is the clearly-visible rear suspension that is all-new. Aluminum lower control arms replace the steel arms used on the current IS F, a nod to the fact that at 3,812 pounds, the current IS F sedan isn't exactly a lightweight. Separate dampers and springs replace the coil-over configuration in the existing IS. In the above photo, the lower spring perch can be seen as the bowed-out section of the lower control arm just slightly inboard of the shock. Furthermore, a new rear toe adjuster or rear-steer ball joint is evident on this mule, something that doesn't exist on the current IS F. See our suspension walkaround of the 2011 Lexus IS F or the above photo of the 2011 model for comparison.
Taking a closer look at the geometry and setup at play here, this next-generation IS's rear suspension is an adaptation of that found under the 2013 Lexus GS. Accordingly, the 2014 IS could employ adjustable damping as well as active rear steering — features that are currently optional on the larger GS sedan.
Inside Line says: The suspension gives it away. Expect the 2014 Lexus IS to break cover in the next 12 months.
Source: Inside Line
Old 07-17-12, 11:00 AM
DOC4LEX
DOC4LEX's Avatar
This could a wait which i don't mind need to get my dollars & sense together for this!!
Old 07-17-12, 11:26 AM
flipside909
Lexus Connoisseur
carbuzz:
InsideLine:
Old 07-18-12, 06:07 AM
YeA 2jZ
YeA 2jZ's Avatar
Nice .........
Old 07-18-12, 12:29 PM
350forMe
350forMe's Avatar
I guess form what i can see this is just an ISF convertible. However insideline says not to be fooled by the body. Makes sense since they usually mask the prototypes with current body parts, it will be interesting to see the new IS with the current style of grill.
Old 07-30-12, 07:20 AM
DOC4LEX
DOC4LEX's Avatar
I wish thier could make the next IS-F coupe an GT86 equivelant less kerb weight about 1400kg,make the GT86 platform bigger to accomidate the body size of the IS-F Coupe engine should remain the same or detune the LFAs V10 to V8 with hybrib option.But keep the car simple!!
Old 07-30-12, 05:09 PM
JessePS
JessePS's Avatar
Now that be something. Seeing I was parked next to a C63 AMG at a light today. I was checking out the specs and what not. It would be interesting to see the IS-F go head-to-head with that beast.
Old 09-03-12, 11:02 AM
DOC4LEX
DOC4LEX's Avatar
Just came back from the BMW dealership my word the new 3 series and 6 coupe are just awasome rides.Lexus then next IS has to that good or better and as well as the SC replacement!!
Old 09-06-12, 10:52 PM
Farbound
Farbound's Avatar
Omai. This looks interesting
Old 09-07-12, 02:08 AM
DOC4LEX
DOC4LEX's Avatar
New IS is rumoured to be sportier and more upmarket than the outgoing model. New IS is reportedly based on the stretched version of the rear-wheel drive platform underpinning the Subaru BRZ and Toyota GT 86.
In addition to standard petrol and diesel engines, a hybrid version is also planned. The top of the range IS-F is very likely going to use a smaller turbocharged unit in favour of the current V8
If gmotors.co.uk is correct with just these two rumors i will be celebrating for days!!!
Old 10-24-12, 11:51 AM
SVTRondogg
SVTRondogg's Avatar
Dying to see the new IS F.
Curated Content Editor
02-22-18 08:30 AM
lexicanto
07-23-14 08:44 PM
XeroK00L
IS F (2008-2014)
17
03-17-06 10:37 PM
GFerg
09-24-05 06:02 PM
Sup
05-18-05 12:51 PM
Quick Reply: IS Convertible Sporting IS F Gear @ Nürburgring
