Throttle response / hesitation
Old Sep 13, 2022 | 06:52 AM
FlyTvr's Avatar
FlyTvr
Default Throttle response / hesitation
Anyone else noticed this? Driving through a sweeping bend, revs quite high, say 5 1/2 thousand, ease off the gas, once through the corner, hard on the gas, and there’s a moment of hesitation.
Granted, it’s ages since I’ve owned a naturally aspirated car, so maybe I am expecting too much. However, I’ve owned an ISF and an RCF and don’t recall this behaviour
Sport plus and gearbox in manual
Old Sep 13, 2022 | 07:11 AM
MLMLC52K18's Avatar
MLMLC52K18
You Go Boyyyy! Like the way you Drive!!!!! My LC has only hesitated when I push it too hard before the engine/trans has warmed up.
Old Sep 13, 2022 | 07:27 AM
Badhobz's Avatar
Badhobz
thats probably the traction control muting response because its detecting you are off angle and trying to figure out if you gas it, will you spin.
Maybe try it with TC off ? or in a straight line and see if that hesitation is still there
Old Sep 13, 2022 | 09:40 AM
almost certainly traction control kicking in.
Old Sep 13, 2022 | 10:55 AM
FlyTvr's Avatar
FlyTvr
Thanks for the replies all.
Interestingly, if I leave the gearbox in auto mode (D), the symptoms seem to go away.
I don’t think it’s traction. It’s more like the engine management software is confused when you back off the throttle and then get back on it. Strange.
Old Sep 13, 2022 | 09:06 PM
perhaps in sport+ the throttle is more aggressive and thus break traction more easily, plus in D maybe your rpms aren't as high and thus less torque.
anyway, you can figure it out by turning off tc.
Old Sep 15, 2022 | 11:52 AM
NoFi's Avatar
NoFi
Should be pretty clear when traction control kicks in though, the car literally bogs down (at least on my GS F it does). Try it out in a straight line and see if it only happens in the corners. If it does, it must be the traction control.
Old Sep 15, 2022 | 07:00 PM
FlyTvr - does your car has limited slip differential? without it, obviously it's easier for one wheel to slip, inducing traction control.
Old Apr 16, 2023 | 02:31 PM
FlyTvr's Avatar
FlyTvr
Yes, it has an LSD (UK Sport + model). I'm convinced it is not a traction issue. I'm frustrated nobody else has encountered this issue. I think I need to drive another LC for comparison purposes.
Old Apr 16, 2023 | 04:09 PM
so did you try it with tc turned off? and try in a straight line as NoFi suggested?
FlexedLEX
IS F (2008-2014)
23
Mar 26, 2020 01:08 PM
Kron1ck
IS F (2008-2014)
17
Apr 29, 2019 07:53 PM
sderman
RX - 4th Gen (2016-2022)
23
Sep 28, 2017 09:19 AM
viperdoc
RX - 3rd Gen (2010-2015)
17
Aug 19, 2013 02:39 PM
niko14
IS F (2008-2014)
16
Feb 22, 2010 04:45 AM
