Upgrading 2018 LC500 to 2022 Specs
Old Jul 24, 2022 | 01:24 AM
North1Star's Avatar
North1Star
Default Upgrading 2018 LC500 to 2022 Specs
I wonder if anyone with good mechanical and technical background can advise if 2018 models of the LC 2018 are upgradable to get all the refinements that the 2019,2020,2021 and 2022 got
The suspension, engine mounts, shift logic, VGRS…etc
I am planning to keep this car for a long time and welling to do these upgrades if possible
I see people here went all the way to changing the differentials internals, so hopefully these smart folks can jump on this project as well and work on it together
2019:
Reprogrammed shift logic for 10-speed automatic transmission
- Range of Adaptive Variable Suspension expanded for enhanced ride comfort
- Enhanced steering, revised VGRS and change to aluminum steering support bracket
- Modified rear engine mounts
2020:
The LC 500’s 10-speed Direct-Shift automatic transmission received updated programming in 2019 to provide smoother shifts at part throttle while still offering more forceful gear changes at wider throttle openings. Updates were also made to the Adaptive Variable Suspension, including new bushings on the damper rods and a switch to independent rebound and compression orifices. Both changes allow for an expanded range of damping force for enhanced overall comfort. To improve steering feel, the assist levels have been altered along with stiffer steering box bushings, a more robust aluminum steering support mounting at the instrument panel and revised Variable Gear Ratio Steering (VGRS) tuning.
2021:
  • Reduction of unsprung weight (approx. 22 lbs.)
  • Suspension updates to provide smoother, softer suspension stroke
    • Electronic absorber controls adjusted, bound stopper rigidity optimized
    • Rear stabilizer rigidity increased to improve front turn-in ability
  • Active Cornering Assist (ACA) added
  • LC 500: Update to transmission timing, logic changes
Old Jul 24, 2022 | 04:16 AM
MLMLC52K18's Avatar
MLMLC52K18
Originally Posted by North1Star
I wonder if anyone with good mechanical and technical background can advise if 2018 models of the LC 2018 are upgradable to get all the refinements that the 2019,2020,2021 and 2022.
Comeon Mannnn.....The cheapest thing to do is to buy a New car!
Old Jul 24, 2022 | 06:54 AM
Badhobz's Avatar
Badhobz
With the used market still being strong I agree. It’s significantly cheaper just to sell your 18’ and buy a newer one.
Old Jul 24, 2022 | 07:52 AM
North1Star's Avatar
North1Star
I don’t think its a bad idea to change the rear engine mounts + the rear stabilizer as a start!
What do you guys think?
Old Jul 24, 2022 | 07:57 AM
Badhobz's Avatar
Badhobz
to each their own, but i wouldnt bother man. First, go drive a brand new one and see if these improvements are even worth the effort and cost. second, no matter what you do suspension/tunning wise this is still a elephant of a car that only does grand touring. this aint a sports car.
Old Jul 24, 2022 | 02:00 PM
breplica's Avatar
breplica
I personally dont think its worth the effort, the changes are mostly subtle. Of them all, IMO probably the best 3 changes are
1 - suspension improvements - maybe try aftermarket coilovers which would be much cheaper. On my brief test of the 2018, i did feel the ride was a bit crashier than it was on the 2022 but its not a huge difference
2 - apple carplay - i think the dealer can install this for you
3 - improvements to gearshift logic - unfortunately this is probably forever beyond your reach unless you upgrade to a later year car. On the 2018 car and i didnt pick up much difference between that and my 2022. And I know for sure even on the 2022 the shift logic is still slightly flawed anyway so i wouldnt place much weight on this
Old Jul 24, 2022 | 06:37 PM
i think that's a very small part of all the changes. also VGRS is only on performance package models. reducing unsprung weight is significant. AVS changes. Android Auto (if important to you, it was a must have for me which is why i got the '21).
but for all the parts you'd need to buy and all the labor involved i suspect it would be whole lot simpler and possibly no more expensive to just trade in an '18 and get a '22.
in other words, if you want all the benefits of the '22, get the '22.
Old Jul 25, 2022 | 05:36 AM
GrandSedanFan's Avatar
GrandSedanFan
A lot of the changes were in tuning of various computers. The transmission, suspension, and engine are all controlled by different computers that not only need to work with whatever changes in hardware were made, but also need to work with each other. Simply changing a computer or a component will not necessarily get you the desired result, and may, in fact, not work at all.
All of this is to say you'd spend less money trading up to a 2021 or 2022.
Old Jul 25, 2022 | 02:00 PM
guanche2k9's Avatar
guanche2k9
Have to agree with most - not worth all the headaches, delays, and cost to get those parts installed on an 18. On top of that, even if you managed to get that done, as @panyo64 said, what guarantees do you have that those components will work with the software? Just for the avoidance of headaches of trying to get all those to work in unison, I'd pay a little extra to get a 21 or 22. Most importantly though, as @Badhobz said, drive the 21 or 22 first, to see if those changes really are worthwhile for your taste.
To each their own.....
Old Jul 27, 2022 | 03:18 PM
North1Star's Avatar
North1Star
Thanks for all the feedback guys. Clearly most improvements are not something easy to do, if not impossible.
I will consider changing the engine mounts to the refined version when it is time to change them.
also, I might look into changing the rear stabilizer since I found it for approx $180 only OEM which Lexus stated that “Rear stabilizer rigidity increased to improve front turn-in ability”
Old Jul 27, 2022 | 04:27 PM
MLMLC52K18's Avatar
MLMLC52K18
'Live Long & Prosper'
Old Jul 27, 2022 | 07:12 PM
flowrider's Avatar
flowrider
Veteran: Air Force
You may also want to look into the Yamaha performance damper. Do you know if your LC has Torsen?
Old Jul 28, 2022 | 12:26 AM
North1Star's Avatar
North1Star
It does have a torsen, I am in the process of getting the TRD damper. Do you think it will be better than the Yamaha?
Old Nov 16, 2025 | 03:37 PM
LegacyLC's Avatar
LegacyLC
Sorry for resurrecting this dead thread! But I was wondering if you ended up able to install the Yamaha/TRD damper on your LC? I have a 2018 coupe and have been struggling to nail down which pn (MS303-11001/4/6) to run with.
Thanks!
Hifiman1
Feb 27, 2026 10:33 AM
quicknight
Suspension and Brakes
Apr 22, 2017 08:18 PM
toyotaman7
RX - 4th Gen (2016-2022)
Jan 11, 2016 02:42 PM
NEWONE1
Oct 22, 2013 12:42 PM
Giggzz
Mar 10, 2007 09:27 AM
