car won't start
Old Dec 25, 2006 | 07:04 AM
eatmorchic's Avatar
eatmorchic
Default car won't start
Got a 1995 ES300. Raining morning Xmas day and car won't start.
When I turn key, I hear rapid clicking sounds. The car hasn't been used in a few days. There is light, radio works. Do you think it's a weak battery or a bad starter? Should I check the distributor cap for wetness?
Old Dec 25, 2006 | 10:51 AM
kingofire's Avatar
kingofire
I doubt its the battery. my guess would be the starter or alternator. Check the cap for wetness but i would doubt its that either.
Old Dec 25, 2006 | 11:17 AM
IDHITIT's Avatar
IDHITIT
Most likely the battery, try to jump start it.. if that doesn't work we can move on to things that cost money.
Old Dec 27, 2006 | 01:15 AM
eatmorchic's Avatar
eatmorchic
Wife finally came back home from outta town and I was able to jump start my car. Left it running for a few minutes, then turned off, then turn back on, it works again. But I will go out and buy a new battery just in case.
Old Dec 27, 2006 | 03:16 PM
IDHITIT's Avatar
IDHITIT
Take the battery down to any Autozone (or equivalent auto parts store) they should test the battery for free.
If the battery is fine but it goes dead again get the alternator checked out.
What that clacking noise was was the starter solenoid didn't have enough juice to keep the starter gear engaged.. so the gear clacked in and out rapidly. It takes far less power to operate the lights/radio.. which is why they still worked.
Old Dec 29, 2006 | 08:24 PM
AdvanSC300's Avatar
AdvanSC300
Always make sure the battery terminals are the tight first,but you may just need a battery,but on the other hand,you may also need a starter if you have high mileage!!Do a starter test on it,by just trying to start it a couple of time,but don't fully start the engine,if at one point it no longer wants to start the engine,and it just does a click(with a good battery of course),thats a good indication of a starter malfunction..
smf8935
Oct 23, 2014 03:26 PM
oslouie
Aug 11, 2011 06:49 PM
werewolf
Nov 12, 2010 12:50 AM
shaitaan
Jun 21, 2006 09:41 PM
jimbo22s
Dec 7, 2004 08:12 PM
