Tire monitoring system
Also, the cold could cause the pressure to drop low enough to set off the sensor. Driving would warm the tires and increase the pressure.
It's worth noting that the system considers "normal" the pressure in each individual tire at the time that the tire pressure monitoring system was last initialized. Unless you've reset it yourself (the button under the dash), that would have last been done by the dealer as part of the pre-delivery service. As has been discussed elsewhere in this forum, some dealers may set pressures higher than the sticker specifies, thus 32.5 lbs. may well be considered low if the system had been initialized at a higher pressure. I haven't seen anything in the manual that tells us exactly how many lbs. a tire must be below the initialization pressure to cause the system to alarm. It might be nice to know that figure.
edit: lets not forget when checking the tires the spare also needs to be checked
On a related note...I prefer to run my tires at 32lbs. so when I took delivery I set them all at that pressure and reset the tire pressure monitoring system. Then I added a couple of extra pound to the spare. Now I have to check the spare only every second or third time and still be confident that it has enough air in it and won't be triggering the monitoring system unnecessarily. Just lazy I guess!
What you're asking for is a very sophisticated monitoring system that would add too much to the cost of the car....although it's a nice idea.
All manufacturers have to have a TPWS as of 2007 model year. The system monitors tire pressures period. It doesnt care if it is hot or cold. Lexus nor any other manufacturer can change physics. When it gets cold, tire pressures will drop. A cold tire at 26psi and a hot tire at 26psi are both seen by this system as 26 psi period. All systems have to notify the consumer when the tire pressure reaches 26 psi. This is the minimum allowed.
Lexus direct tire sensor systems must be initialized properly in order to work properly. Also at some point, we as consumers must take a little responsibility and accept the fact that 26 psi hot or cold will turn the light on.
This system is fairly accurate and simple to use if initialized properly. If you will set your tire pressures to 32psi (cold tires) and then initialize the system, it will set your thresholds to 26psi. This system will set thresholds of 18% loss of pressure when you initialize.
Examples: 18% of 32 = 6 / 32 - 6 = 26 Light on at 26psi
18% of 40 = 7 / 40 - 7 = 33 Light on at 33 psi
If you initialize tires with 32psi your threshold is 26psi
If you initialize tires with 40psi your threshold is 33psi
Lets assume it is 70 degrees outside and you initialize your tires when they are hot and at 32 psi. When they cool off, they will be approx 28 psi. Now the outside temperature drops to 40 degrees. Your tires now will be somewhere between 24-26 psi. Light on. Drive for a few miles and yes the light will go off because psi raised above 26.
If you use the same scenario BUT initialize the system when your tires are cold and 32 psi. When temperature drops to 40 degrees the tires will have 28-30 psi and NO LIGHT ON.
I do agree that the system should tell which tire is in fact low. Other than that, this system works as designed and only as good as it is initialized.
