Help and Opinion is greatly aprriciate(PIC*Rims & tires)
Here is the spec of the tire:
40 series tires on 18 inch rims
Ventus by Hankook tires 225/40/18 radial tubeless tires
5 lug zoom alloy rims
The tire size on my 00 ES is P205/65R15 92V or P215/60R16 91V
Anything that i should be worry about beside checking if the 5 lugs (i guess it is called offset) fit my lexus?
Thx
You'll need a 5 X 4.5 OR 5 X 114.3 MM bolt pattern on the rim to mount it.
I think you need something along +35 offset or more for proper fitment.
I have +38 on mines. Someone else might have to clarify how low an offset you can go. Good Luck
Goodluck
charley
forget about tire size and guessing what size rim is...
you need to find out exactly the width and offset.
8.5 on width is the widest you'de want to go. ( unless you are willing to do fender mods and such, like fender rollin some neg camber and a mild stretch on tire. the a 9 is the way to go for the exe/vip style)
but nontheless, an 8 or 8.5 is nice.
Offset for the norm (8 or 8.5)should be in the 30's...example +32 +35 +37
if you want to go low and aggressive, than you can push boundries and run mid to high 20's in offset....example +23 +25 +28 ( note, this would take work but look mean)
good luck..... by the way thats a clean lookng wheel
http://www.rsracing.com/tech-wheel.html#backspace
again, thx
