Fuses
Old Mar 1, 2003 | 11:12 PM
NoRyceGS4's Avatar
NoRyceGS4
Default Fuses
can anyone here give me a detailed description of which fuses to replace for the car's sound system and such? thanks
Old Mar 3, 2003 | 01:46 AM
Jmai22's Avatar
Jmai22
is this stock fuse?? if its stock fuse it should be under the fuse box cap. if its not under there just replace it with the same fuse that burnt out.
If its an aftermarket sound system that keeps popping. check all your wiring. if its still popping and you still think the fuse is too low, just add up all your internal fuse on all your amps and stick a fuse under the hood for that amount
Old Mar 7, 2003 | 11:47 AM
LEXBERG's Avatar
LEXBERG
does anyone know if fuses are responsible for the brightness on the interior lighst. Like the ones on the window buttons....
Old Mar 7, 2003 | 12:13 PM
retrodrive's Avatar
retrodrive
Search Function Inc.
If you guys still have the manual for your car, all the info on the fuses should be there. There is a really easy to understand table that describes what goes where.
pentiumvi
RX - 4th Gen (2016-2022)
41
Nov 12, 2024 09:47 PM
SparkLex
Sep 5, 2015 11:44 AM
JSlaughta
GS - 1st Gen (1993-1997)
Apr 26, 2013 08:14 PM
spxChrome
Jul 10, 2006 04:54 PM
