Audio Control LC6 + JL 500/1 amp
Subscribe
Mar 19, 2014 | 09:06 PM
Alright guys, I know a lot of you guys are running LOC's with a JL 500/1 amp. I need help with some of the settings on the JL 500/1. I was wondering if the guys running the audio control LOC are you guys running your amp on Low volts or high volts?? I tried using a DMM to configure my gain today and I couldn't even get my VOLTS up anywhere near 31.62 with the amp on switched to high volts... I then turned it to Low and got it up near there, but my question is, why can't the amp get that much volts when the Audio Control LOC is supposed to push out 9v? Should I run the amp on Low volts then??
Reply 0
Mar 21, 2014 | 10:53 PM
If you are using RCAs from the LC6 to the JL then you should be using the low voltage input. The high voltage input is for a speaker level input directly into the amp. You are using the LC6 to convert your high level input to a low level.
Reply 0
Mar 24, 2014 | 05:08 PM
correct.. and you should be able to leave the amps gains all the way down to eliminate any noise or distortion..
Reply 0
Subscribe
