Weird problem, please help
Old Nov 1, 2002 | 02:31 AM
kasper634's Avatar
kasper634
Question Weird problem, please help
Aight i got this little problem im having with my 93 gs, it seemed to happen only when its raining but it just happened again few days ago when it wasnt and the roads were dry. But when i drive and stop at a stop sign or red light but it happens only when the car is idling, the battery light comes on, the abs light comes on the track and trac off light comes on and everything dims... when i add gas it goes away, it happens a couple of times then it goes away? at one time the radio shutoff on me any ideas? please help!! thanks!
Old Nov 1, 2002 | 02:40 AM
pcmw's Avatar
pcmw
I think it is your battery, altenator, or cables.
Take it to a shop and have them test it before you blow the battery or do more damage.
MW
Old Nov 1, 2002 | 04:43 PM
engin_ear's Avatar
engin_ear
Everything in Moderation
It is probably your battery going kaput, and/or alternator failing to regulate. Take pcmw's advice!
What you're likely seeing is the voltage dropping and causing the radio to shut down, which I've seen happen in my newer GS when the battery is low. The rest of the car still runs, but weird things start happening because all of the electronics do not have the proper supply voltages. You'll get random intermittent indicators going off. It could also be a short or partial short elsewhere in the system, causing the same secondary effects.
Old Nov 2, 2002 | 12:06 AM
kasper634's Avatar
kasper634
ok thanks guys for the quick respones,well i think there is a short somewhere, when i start the car the indicator on the dashboard comes up that one of my brakelights are out.. but they all seem to be wqoorking. do i have to hook it up to a diag. computer to reset it or what? also the battery i have in there is stock i dont think it has ever been replaced. whats a good quality batter that anyone recommends? i dont have a spending limit i just wanna get my car running smoothly.
Old Nov 2, 2002 | 02:17 PM
LexusDS's Avatar
LexusDS
Daystarter battery is pretty good it also has a 5 year warranty.
Interstate is a very reliable one also.
Good luck.
LexusDS
Old Nov 4, 2002 | 12:26 PM
engin_ear's Avatar
engin_ear
The common battery recommended in these here threads is Optima. They make gel electrolyte batteries that even Consumer Reports rated very highly. They are more expensive however. Optima makes a Red Top, good if you have no added stereo system or other heavy drain, or a Yellow Top, better for heavy drain applications like stereos due to ability to recharge many times from deep discharge state. You can search the threads for more info on these in the threads. By the way, Optimas are not a direct fit, you may need a spacer, etc.
Other good battery is Sears DieHard Gold, made by Johnson Controls. Very good starting battery, but is not meant to be deep-cycled many times. Will cease to recharge if drained too many times by accessories.
kaedachef
May 29, 2016 08:03 PM
SC430Sam
RX - 1st Gen (1999-2003)
Jun 9, 2010 09:03 PM
4double0
Jun 27, 2008 08:44 PM
mikeloc24
Apr 25, 2007 02:27 PM
JohnnySC
Apr 12, 2005 10:22 PM
