No More Whining on Aftermarket Head Unit/Stereo
Combine this with proper grounding under the hood, as stated above, and you should have no ground concerns with amps or decks.
Big Mack
I have a similar problem, although I may need a different solution since I have a carPC and not a regular stereo setup.
I have a whining described exactly as above (that goes up and down with my rpms), that is only heard while the carPC is off. And since it takes a few seconds to boot up you hear it when you first start the car, then it goes away 99% when the computer is on. Obviously the computer completes some sort of ground and the whine goes away.
But since the linked websites say that the cause is a deeper underlying issue, I wanna fix it. Anyone have any suggestions? Ground the PC better maybe?
i would take out the headunit and check to make sure all the wires are connected in the first place. if theyre all good, then you can try putting the ground wire on different things and see if it improves.
poutsa
05-10-07 03:17 PM
Stage3
02-24-04 07:36 PM
