Relay Question
Old Nov 16, 2011 | 01:21 PM
lexus-is2's Avatar
lexus-is2
Default Relay Question
I have a relay that I am working with, the relay is activated by a power source connecting to the positive and negative of the relay. however, the source that i am trying to use to activate the relay changes polarity. I only want the relay to activate if polarity is certain way. can anyone tell me if the polarity is reversed on the relay activation, will the relay still work or will it blow?
Old Nov 16, 2011 | 02:29 PM
Big Mack's Avatar
Big Mack
Question
What are you using to activate the relay? If hooked up properly, it would only activate when seeing the correct signal, but it would be a DC signal, not AC if it's for your car. A 12VDC relay should not be used in an AC circuit. Are you using an AC relay in a different application?
Big Mack
Old Nov 16, 2011 | 10:39 PM
lexus-is2's Avatar
lexus-is2
It is a 12V DC relay. the relay has a red and black cable to activate it, if i put positive on the red and negative on the black, then it activates. what will happen if i put it the reverse way, positive on black and negative on red? will it blow the relay or will it simply just not function?
Old Nov 18, 2011 | 06:24 AM
nervekiler's Avatar
nervekiler
it should still work. you wanna make sure you are using poles 85 and 86. make sure the wires do not t off or loop to 30 87 or 87a. it should work if you reverse polarity of 85 and 86, will still activate.
but of course there is only one way to find out....
make sure you use a fuse!
Old Nov 19, 2011 | 09:14 AM
Big Mack's Avatar
Big Mack
Cool
Correct on both counts. Use the smallest (ratings wise, not physically) that will handle your current demands. And it will still work if hooked up in reverse polarity. All it's looking for is the circuit to be completed in order to turn on the switch.
Big Mack
LexoticJ
May 2, 2015 11:40 AM
supraclay
Nov 12, 2012 05:06 PM
dadewi
GS - 1st Gen (1993-1997)
Apr 24, 2009 04:09 AM
Maxx941
Oct 10, 2008 09:59 AM
