Sub Box installation question
Old Oct 26, 2011 | 03:10 PM
WIZARD1325's Avatar
WIZARD1325
Default Sub Box installation question
Ok I ordered these dynamate square rubber thingies that are suppose to be installed behind the sub
I have spare dynamate should I lace the walls with dynamate?
Attached Thumbnails Sub Box installation question-295913_2336009233908_1060153505_4653026_1179323199_n.jpg   Sub Box installation question-310973_2336010313935_1060153505_4653028_847287507_n.jpg
Old Oct 26, 2011 | 03:16 PM
oslouie's Avatar
oslouie
Actually, those are supposed to be installed behind your door speakers, not inside of a sub box.
EDIT: Nevermind. I just did a little more researching and found that it can be used inside of sub boxes but I've never seen anyone use that stuff inside a sub box. You're better off with polyfill inside a sub box as far as standing waves go. I would only use those pads behind the speaker inside of a door though. Just my .02.
Old Oct 27, 2011 | 01:01 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
Personally I never put anything in my enclosures. Polyfill is used to reduce standing waves and to "trick" the sub into believing the enclosure is slightly larger but...... As far as those dynamat pieces go? My opinion......marketing hype.
Old Oct 28, 2011 | 09:02 AM
oslouie's Avatar
oslouie
I agree. I think it's effective if you put it behind the door speakers as mentioned but then there's cheaper alternatives like closed cell foam.
Old Nov 2, 2011 | 09:32 PM
DubbStep's Avatar
DubbStep
Agreed, But also never put Dynomate in a box, the rubber ones are fine, it will take away if you do;(
Old Nov 3, 2011 | 09:27 AM
Robert_J's Avatar
Robert_J
The waves in the sub range are longer than the length of the car. It is physically impossible to have standing waves in a sub enclosure. Polyfil slows the rear wave by converting some motion to heat and thereby making the enclosure seem about 10% larger when you use 1 pound per cubic foot of stuffing.
The dampening pad installed will take up a small amount of air space. It will also lower the resonant frequency the back panel vibrates at. You want to either raise the resonant frequency or lower it outside of the sub's passband.
maxx430
Nov 29, 2012 08:38 AM
ES-3
General Classifieds
Nov 14, 2008 06:35 AM
handzilla
Jul 11, 2006 06:08 AM
TGRich
Jul 2, 2004 12:30 AM
Lvangundy
46
Dec 9, 2002 11:08 PM
