Adding an AUX input to 95 ES 300
Old Sep 5, 2011 | 04:32 PM
lvicks's Avatar
lvicks
Default Adding an AUX input to 95 ES 300
Hello,
I just bought a 1995 ES 300 that's in pretty good condition. I think the CD player in the trunk works, but I want to wire a 1/4" RCA input (or ipod connector, etc).
Based on this tutorial aux input to OEM stereo and this wiring info it should be pretty straight forward, I don't care about the CD so I just need to re-direct the CD out lines to my cable.
I have a few questions hoping you guys had some input:
1) Good tutorial on removing the ES 300 OEM stereo face plate. I'm handy w/ electronics/tools but never modified a car before.
2) The wiring info says there's a "Car Radio Accessory Switched 12v+ Wire". What's this and when does it get 'switched' on? Perhaps I can use this to charge the ipod.
3) It says the Stereo amp is located right of the glove box. I don't care about this right? Since there's a CD button on the stereo it means the CD signal passes through the signal.
4) How do I know what the CD input cables are? The wiring info doesn't mention it.
thanks!
L
Old Sep 6, 2011 | 06:01 AM
Shibumi1's Avatar
Shibumi1
the car radio accessory switched 12+ wire shows 12volts when the ignition switch is turned on an ground when its off... yes u can use it to charge ur ipod..
u'll still need the the factory amp thats how u feed the ipod signal into the oem system..you'll wind up pressing the cd button to get that as an audio source then the extra switch is used to toggle between ipod an cd
Old Sep 6, 2011 | 12:35 PM
rgarjr's Avatar
rgarjr
That wiring info link does not give u any info on what wires carry the CD changers audio. U need to look for a schematic.
Old Jan 9, 2012 | 12:43 PM
lvicks's Avatar
lvicks
FYI Plan is to tap into the Teal, Purple, Green and Blue wires. My CD player is bunk so I don't need to make a switch just cut and tap.
See the attached diagram. I will report back once it's done!
Attached Thumbnails Adding an AUX input to 95 ES 300-screen-shot-2012-01-09-at-3.42.23-pm.jpg
OlderLex
Sep 28, 2017 06:43 PM
kirkllee
May 23, 2010 12:07 AM
Solo626
Mar 7, 2010 07:42 AM
RA051624
12
Jan 26, 2009 11:05 AM
sk72
Sep 2, 2007 02:49 AM
