Dedicated Ignition circuit?
Old Jun 23, 2011 | 06:18 AM
Boyscout's Avatar
Boyscout
Default Dedicated Ignition circuit?
I am doing an install on my 91 Celsior (LS400) and the instructions say i need a "dedicated ignition circuit" for the power. this is obviously because if i hook it to the constant 12V, the lead will always be hot, even if the car is not running. I believe it needs a dedicated circuit because of the high draw when its on.
my questions are:
1) is there a way to set up a dedicated circuit?
or
2) should i just use a relay from the 12V battery (to power the device) and using an existing ignition to close the relay?
thanks for the help
Old Jun 23, 2011 | 06:57 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
What are you installing?
My not just use true ignition? Black with Orange trace in the ignition switch harness. Don't use the Black/Yellow Ignition 2 though.
Old Jun 24, 2011 | 06:01 AM
Boyscout's Avatar
Boyscout
Installing a Methanol Injection pump. when running it will use a lot of power, and i dont want the circuit i piggyback on to blow.
where is the ignition switch harness?
Old Jun 24, 2011 | 07:02 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Most of the pumps I just looked up have a 10A draw on them so you should be perfectly fine using the true ignition wire in the Ignition switch harness.
But to be safe you may want to use the accessory wire to trigger a SPDT relay. If Ignition is used then the pump will be coming on during crank. Accessory is Pink/Blue. Run a jumper from Acc to pole 86, ground to pole 85. Run a fused power line to pole 30 and the power connection from the pump goes to pole 87.
Drop the dash and the steering column shroud and the ignition switch harness comes from the key cylinder.
Old Jun 25, 2011 | 12:42 PM
Boyscout's Avatar
Boyscout
the pump is pressure activated so i wouldnt have to worry about the pump coming on during crank.
so can i use the ignition to trigger the relay?
Old Jun 25, 2011 | 04:14 PM
Big Mack's Avatar
Big Mack
Cool
Yes, just run it to 86 and wire the rest as indicated before. Don't forget the fuse.
Big Mack
mtparker18
Sep 21, 2009 05:02 AM
lexs300
May 8, 2008 06:54 AM
jishan
RX - 1st Gen (1999-2003)
Feb 23, 2008 08:21 AM
awj
Aug 4, 2002 05:23 PM
