Alarm install. Cant find parking lights wire?
Old Jun 3, 2011 | 09:30 AM
Rollaboy's Avatar
Rollaboy
Default Alarm install. Cant find parking lights wire?
Hey folks
I have installed my viper alarm today.
But i cant find two wires. The first is the parking lights wire. According to the12volt.com it should be green and in the black connector at the steering colum. Well i cant find it?
http://www.the12volt.com/installbay/...tail/1280.html
And then for remote start to work i need to wire up the neutral safety wire. I have removed the middle console and looked but cant find anything.
Anyone who can help me?
I have tried to search but cant find anything. Thank you very much.
Old Jun 9, 2011 | 08:16 AM
Rollaboy's Avatar
Rollaboy
Really no one that knows the color of the wires and where i find them?
I have to take apart the whole steering colum :-(
I want the blinkers to blink when i activate/deactivate the alarm.
Old Jun 9, 2011 | 12:22 PM
kamlung's Avatar
kamlung
are you asking about the wire to tap for the blinkers or the parking lights? your first post references the parking lights, then your second says blinkers...
do you have a meter? you can follow the turn signal switch to the inside of the steering column and the harness just plugs into the lever... meter the wires to find the right one for the parking lights...
as for the neutral safety switch, i usually only use those on MT... if your car is an AT, just ground that wire, since you will always have the car in Park when starting...
LEXUS
MODEL YEAR(S)
LS400 1990 -1994
PARKING LIGHTS ( - ) GREEN/WHITE (-) IN BLACK Plug @ STEERING COLUMN HARNESS
PARKING LIGHTS ( + ) GREEN (+) IN BLACK Plug @ STEERING COLUMN HARNESS
Old Jun 10, 2011 | 08:50 AM
Rollaboy's Avatar
Rollaboy
Hi thank you for your help.
I think i got a little confused on the english words. I'm from Denmark and not the beeest at spelling etc.
But yeah i would like the amber blinker lights to be activated. I dont have amber sidemarkers on my car. I know many US cars have that. Are those called the parking lights? Sorry i know it might sound stupid for you 8-)
As for the parking wire, yeah i will just ground it then.
Thank you.
Old Jun 13, 2011 | 08:22 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Just like Kamlung stated
Do you know if you need positive or negative parking lights? What does your unit supply? Does it have both?
I don't recommend you flash the turn signals. Stick to the parking lights.
Just ground the neutral safety wire. No need to actually find it at the shifter. The will not start unless it is in park or neutral anyway. There is already a built in neutral safety switch in the car.
Lastly, since it appears you are just blindly connecting wires to other wires based solely on wire color be prepared for damage to your car. Failure to meter wires (especially when done by a novice or untrained installer) almost definately leads to damage and fire. Please take your car to a certified installer.
Old Jun 15, 2011 | 02:00 PM
Rollaboy's Avatar
Rollaboy
Its not like im blindly connection wires. I think its because maybe there are differences in the wiring from us and europe models.
Why dont you recommend using the flash signals? That would be the best imo? Its easy to find the car quick if the amber flash lights blinks all the way around.
But thank you for your help. I will look some more into the wires and measure what i will be needing.
raine
Dec 21, 2009 04:03 PM
tritron
Jul 29, 2009 06:54 PM
raine
May 28, 2009 02:27 PM
tritron
May 3, 2007 04:46 PM
electro992
Mar 22, 2005 11:12 AM
