Sub woofer not working.
Old Dec 17, 2010 | 12:56 PM
RA030926's Avatar
RA030926
Default Sub woofer not working.
HHelp! My aftermarket sub woofer stopped working. I have the sub hooked up to my 250/1 amp and it usually turns on when there's incoming audio signal. It is tapped into the audio line (pink and light blue wires). Do you think it is a fuse problem? Car oem Amp fuse? I know the sub is not blown.
Old Dec 18, 2010 | 11:27 AM
Big Mack's Avatar
Big Mack
Cool
Is it the JL Audio 250/1? If so, and you are using the signal turn on, that's your problem. It is not designed to turn on with a low pass circuit. They designed it to turn on with midrange signals present.
And how would we know if your fuse is blown, mang? I cannot check it from here. My ESPN doesn't have that kind of range...
Big Mack
ton3r
Oct 3, 2008 08:00 PM
Pineapple
Aug 7, 2007 09:22 PM
RayGS3
Sep 4, 2004 12:45 AM
D-MAN63
Nov 23, 2003 04:02 PM
