IS250 subwoofer install help
Old Aug 14, 2010 | 11:37 AM
RA030926's Avatar
RA030926
Default IS250 subwoofer install help
Hi, im adding a monoblock amp with an aftermarket subwoofer to my car. I need help finding the acessory wire to run the remote start for my amp. Also I have a line output converter but im not really sure where to find the harness at or which one im suppose to use on the factory amp. Thanks!
Old Aug 14, 2010 | 12:30 PM
whitecel's Avatar
whitecel
Factory amp is located in the trunk. Right side under the plastic panel.
Old Aug 14, 2010 | 04:46 PM
RA030926's Avatar
RA030926
yeah i need help figureing which harnesses to use
Old Aug 14, 2010 | 06:48 PM
whitecel's Avatar
whitecel
ml or non-ml?
Old Aug 15, 2010 | 03:50 AM
RA030926's Avatar
RA030926
non ml, which wire should i t-tap into? , also should i dc the rear sub, or just cut it on the wiring harness?
Old Aug 15, 2010 | 05:29 PM
RA030926's Avatar
RA030926
anyone?????
VIPnsanity
Dec 17, 2009 12:10 PM
D.Jobin
Mar 20, 2008 02:19 PM
1022it
Feb 14, 2007 11:08 AM
