Lexus Radio
Old Jul 1, 2002 | 02:38 PM
SharpLS-96's Avatar
SharpLS-96
Default Lexus Radio
Surveying the best car stereo OEM
http://www.laaudiofile.com/newcar.html
Old Jul 2, 2002 | 10:42 AM
Percy's Avatar
Percy
Moderator - Electronics Forum
25 Year Member
They didn't take into account the Mark Levinson system nor the Volvo (Dynaudio equipped) systems. OEM wise, I'd rank the Mark Levinson system as one of the best available. But, the ML won't compare with a high end aftermarket installation.
Percy
Old Jul 2, 2002 | 11:58 AM
engin_ear's Avatar
engin_ear
Everything in Moderation
Default Nakamichi
A lot of talk about Nakamichi in that writeup. I don't know which Lexus model they're referring to when they say you can crank the Nak system up all the way without distortion, but I just ran some tests on my '99 GS400 Nakamichi system (which actually has a (factory) Pioneer changer mated to it; I was a bit shocked when I found that it did not say 'Nakamichi'), with the following results:
With a CBS test disc playing a pure sinewave at the 0dBFS level (tip of sinewave reaches maximum digital level), I measured the onset of clipping at a volume setting of about 3:00, or about 3/4 of the way up. The result of this is that if you're playing a 'hot' disc, one that was recorded or re-adjusted to get levels that use all of the digital bit range (for best signal to noise) - and there are many - playing at loud levels with the volume turned most of the way up will be distorted. (It'll be loud, though!)
The other thing is that the GS Nak door speakers, while better than the Lex stock Pioneer speakers, are only 4" and leave a lot to be desired. The tweeters actually have a coating an them that looks like something between tar and plastic, not real great for linear HF reproduction. Don't know if other models have larger sized door speakers. This is generally the biggest problem with MOST of the OEM factory systems - the speakers just plain suck.
Though I have not heard it yet, my money would be on the Volvo, with the factory-supplied Dynaudios, as Percy mentioned, on speaker reputation alone.
e-man
May 3, 2014 11:39 PM
Gix3
GS - 1st Gen (1993-1997)
Mar 28, 2006 07:37 AM
teutonictr
Nov 2, 2004 01:34 PM
Rudy Crichlow
Nov 8, 2002 05:23 AM
Silver328is
12
Sep 10, 2002 02:23 AM
