Voice Amp Keep Shutting Off Help
NELOC Moderator
Guys,
I had this problem for the longest now, but I never really knew what was the exact problem until today when I was putting in some new wires. When I would raise the volume up a lot my interior speakers would shut off leaving the subs thumping until they come back on (weird but there are a few songs that I could play w/ the volume max and the amp would never trip) . This afternoon I finally got my hands on some longer speakers wires and decided to rest the subs on the outside of the car & observe the amps. With the volume & bass on high my interior speaks went out which was not a surprise at all. What I noticed when the speakers went out the green light on the voice amp turned red which indicates the amp tripped obviously.
Here is the spec on both amp and Component Speakers, please let me know which you think I should replace & with what... (looking for something w/ a lot of mids)
Kicker KS-Series 05KS65.2 6-1/2"
Peak Power Handling: 150 watts
RMS Power Handling: 75 watts
Sensitivity: 88 dB
Frequency Response: 35 Hz - 21 kHz
Impedance: 4 ohms
Kicker 06ZX350.4
* 4-channel car amplifier
* 60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
* 175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
* Variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
* Variable bass boost (0-18 dB at 40 Hz)
Thanks in advance for your input
Sensitivity: 88 dB
Impedance: 4 ohms
Kicker 06ZX350.4
NELOC Moderator
NELOC Moderator
I am not certain which goes where first as the wiring process was done at a local shop (which is no longer in business) I do believe there is a splitter
NELOC Moderator
The next thing i want to do is to troubleshoot all 4 interior speakers individually to see if there is any shortage...anyone have any suggestion on the best way go about doing this?
if theyre working fine at low volume, and when u crank them up they cut out. it just sounds like youre overloading the amp. most likely you just need a stronger amp that can supply your speakers.
as far as troubleshooting goes. unplug two speakers from the amp and then crank it up to the point where it used to cut out, and if it doesnt do it then change you need a different amp. just remember which wires go where and the position, unplug the front two first then unplug the back two see if it still cuts out.
NELOC Moderator
I'll let you know the outcome...the weather will be good this weekend so im hoping to get this done by then.
thanks again budd
NELOC Moderator
Guys,
Sensitivity: 88 dB
Impedance: 4 ohms
Kicker 06ZX350.4
Sensitivity: 88 dB
Impedance: 4 ohms
Kicker 06ZX350.4
I'd start with one speaker connected and then turn it up. If it doesn't cut off then disconnect it and connect another one. Repeat until you find the one that is causing the problem. Also make sure your gain isn't turned all the way up causing excessive clipping which can throw the amp into protection as well.
If everything checks ok but is still cutting off with 4 speakers connected you may just have a bad amp. Any decent amp shouldn't cutoff driving 4 speakers at a moderately high volume if the wiring is correct and driven within the amp's ohm limit.
Guys,
Sensitivity: 88 dB
Impedance: 4 ohms
Kicker 06ZX350.4
Sensitivity: 88 dB
Impedance: 4 ohms
Kicker 06ZX350.4
