Help again (Alarm keeps going off)
Old Dec 2, 2008 | 03:47 PM
alotakoon's Avatar
alotakoon
Default Help again (Alarm keeps going off)
https://www.clublexus.com/forums/sho...d.php?t=384638
Well that was my original problem...I replaced my battery today..all was well until i came inside...about lettin the car sit for 2-3 hours with my doors locked...my alarm goes off!!! i really don't know WHAT it is that is setting it off.is there anyway to disable the alarm? but then again..if i disable it..i will still run my new battery out because it seems as it the car would stay on the "ON" position as if there was a key in it with the dash lights and everything on..could there be a short somewhere? i dont kno!!!! inputs, ideas and solutions will be greatly appreciated.
Old Dec 6, 2008 | 03:17 PM
alotakoon's Avatar
alotakoon
please!!!! any help? i was late for work 3 times already because of this..
Old Dec 6, 2008 | 03:26 PM
davidv433's Avatar
davidv433
is this the factory alarm or an aftermarket unit?
Old Dec 7, 2008 | 01:50 PM
alotakoon's Avatar
alotakoon
factory alarm
Old Dec 7, 2008 | 05:57 PM
turbodremz's Avatar
turbodremz
mine did the same thing about 3 weeks ago and no one gave any answer..
I disconnected my battery with the doors unlocked, waited about 5 min, then connected it back and locked the doors with the key and it hasnt done it since.
Old Dec 7, 2008 | 06:32 PM
JonSC4's Avatar
JonSC4
That happened to me too when I replaced my battery. There is a toggle down at the bottom of the lower steering column area trim. I just randomly flipped it back and forth while turning the key on and off and after a few tries it went back to normal.
In the meantime you can pull one of the interior fuses to disable the alarm and keep it from going off while you're at home.
tjone
Oct 6, 2017 12:32 PM
GsLex00
Feb 27, 2016 12:10 AM
lolSC600
Aug 23, 2010 06:57 AM
saelee39
Oct 1, 2007 05:23 PM
asufrin
Feb 28, 2003 04:36 AM
