What is the Best Free Air Subwoofers for the GS 10-12"
Old 03-02-02, 10:49 PM
  #46
dagr8tsthustla
dagr8tsthustla's Avatar
Question
Hey Mean Gene...don't really want to post a new thread for this so I'll just ask....what do you think about a 5-channel amp to run everything...ex: mids, highs and sub? also what 5-channel would you suggest for which ever JL you suggest.
Also, I don't want to upgrade door speakers just yet....but what woould you suggest?
Old 03-03-02, 12:17 AM
  #47
Mean Gene
Mean Gene's Avatar
Question OK
Dag - It depends on just how much of an upgrade U want. A good 5 channel amp won't take up much space or pull much amperage & when coupled with upgraded speakers like Diamond Audio or Boston Acoustics ( or Dynaudio, Focal or Arc Audio, if you're really serious about improving things & your budget allows ) would wake things up quite a bit. Truthfully, I'd recommend that the 3 top-of-the-line speaker brands be wired into separate 2 channel amps to justify their costs & bring out the best performance but that's just my .02. About the 5 channel amp - just make sure it has a separate power supply for the mono subwoofer section ( RF & Kicker's multi-channel amps do ). If not, the shared power supply will find itself pulling power from the smaller speakers whenever a big bass note hits.
As far as the doors go, the greatest sound improvement U could make would be to change out the pitiful 4" factory speakers & replace them with better quality drivers. Unfortunately, I think those 4" speakers R only 2 ohm ( to make the most of the limited power the factory amp supplies ) so it's almost a necessity to then upgrade your amp because the factory amp really won't supply enough power to make the change worth the effort. Of course, U could always change the door speakers w/o adding an amp to see if that would be enough to please your ears. U can easily add an amp later if necessary.
iVIPGS
09-14-11 08:24 AM
melymel96
14
08-18-05 04:52 PM
Lev
11-11-04 09:35 AM
mrshabo
03-09-04 03:08 PM
APLUS
11-13-02 04:08 PM
Quick Reply: What is the Best Free Air Subwoofers for the GS 10-12"
