My factory 12 cd changer does not work and my plan was to install a 2din AVIC D3, or JVC, Kenwood etc etc indash screen. Couple questions.
Any difference in fitment with a 6.5 opposed to 7?
Will my stock speakers play through the 2Din? I heard someone say it couldn't be done.. which makes no sense to me.
well... you won't need the amp bypass. the factory integration harness will work for your vehicle as far as I know. the only part you should worry about is the dash kit. I haven't seen one for that vehicle still. unless you don't mind having the hole, I would check around and see. some ppl are just putting pieces of abs plastic in the gaps to fill it in... GL
